Mach Discussion => Mach Screens => Finished Screens => Topic started by: big-tex on March 14, 2014, 04:07:00 PM
Title: Mach Blue Probing by Big-Tex - new version 3.4 avaliable soon
Post by: big-tex on March 14, 2014, 04:07:00 PM
Currently testing with no problems found
Title: Re: Mach Blue Probing by Big-Tex - new version 3.4 avaliable soon
Post by: dude1 on March 14, 2014, 07:20:15 PM
have a question about your probing program have you fixed the problem with retract.
I ask this as when I was using your z probing it quite often crashed into the table. I changed it to one I got from hosses web site and the problem went away.
the only differences was it included retract.
Post by: big-tex on March 14, 2014, 07:32:33 PM
at what function/ part of program did ou have issues with retracting?
Post by: dude1 on March 14, 2014, 07:54:35 PM
if I did not reff all home more than 25 mm / 1 inch above the work pieces it would crash straight down I have a very big machine that I don't always have the homing switches on or I just did not have enough hight left above the work pices to do it.
I have never had a problem since I changed the codes.
your screen set is very good that is the only problem I ever had with it.
Post by: big-tex on March 14, 2014, 09:04:07 PM
new screen set that is about to release is ment for metric and imperial, it is critical you designate z max or z zero in machine coordinates, referencing z axis take care of that.  New viideo that will be posted on youtube explains lot of your issues. Also I am creating website that users can directly send issues or concens that may come as posiible future upgrades.
Post by: big-tex on March 15, 2014, 02:51:30 PM
TESTING UPDATE: currently running cycle of 1296 of tool change with no problems
videos
http://www.youtube.com/user/BigTexCNC
Post by: Vetsen on March 17, 2014, 10:38:07 AM
where can someone get the new version?
-Vetsen
Post by: big-tex on March 17, 2014, 12:04:11 PM
One more YouTube video pending, list of keyboard shortcuts etc.
I am hoping end of the week. Unless I get more jobs in and those take priority.
Post by: big-tex on March 29, 2014, 06:24:48 PM
New videos uploaded to you tube.
Credit for creating original Blue screen goes to MrBean and SantiniUK.
I have added tool zeroing functionality etc.
New verision is about to be released.
I am hoping this weekend.
Post by: big-tex on March 29, 2014, 10:11:59 PM
new version is released !
Post by: big-tex on March 31, 2014, 06:59:14 PM
Officially out.
Thank you alll for great support
Post by: Vetsen on April 05, 2014, 04:03:44 PM
I'm having trouble loading the screen set.  It's as if the JPG is not loaded or found.
(https://dl.dropboxusercontent.com/u/82376106/Screenshot%202014-04-04%2003.10.14.png)
Post by: big-tex on April 05, 2014, 04:10:44 PM
please let me know where is your mach 3 installed?
C://mach3
Post by: big-tex on April 05, 2014, 04:14:36 PM
Keep in mind during install you need to indicate where mach3 is installed.
I do have youtube video showing installation process
https://www.youtube.com/watch?v=lVX537uj1cU&feature=youtu.be
Its is also good idea to have previous verion of my screen uninstalled as good measure.
Its been several years and I did not have all of my old filles to create installer as upgrade.
Post by: Snortin on April 21, 2014, 10:07:22 AM
I am having the same issue with my screenset.  All the files are in the correct location, loads but all I get is the black death.  I have tried this on two different machines and also tried different profiles to see if there was something in the profile that was messing it up.  Any suggestions for a fix?
Thank you,
JH
Post by: big-tex on April 21, 2014, 11:28:42 AM
Shot me emails I will resend install files, just in case of corruption
Post by: ZASto on April 21, 2014, 11:48:26 AM
Hi Thomas,
can you send me your script for TC Zero Setup?
I'm using your latest public domain screenset, heavily modified for all the functions to be mm/inch, and found, just yesterday, that if the fixed plate is higher than material surface, tool is never reaching material for cutting.
10x
Post by: big-tex on April 21, 2014, 12:10:26 PM
It should be cutting fine calculated offset will be positive #, if plate is below material it will be negative #.
If you refer to verions prior to 3.4 you need to do it using my site to get files.
Post by: big-tex on April 21, 2014, 11:39:24 PM
issue fixed check your email
if something needs further rework let me know
Post by: ZASto on April 22, 2014, 02:05:49 AM
Thomas,
thank you for your kind offer, M'a Baker style :)
Will have to put my brain to overdrive again.
Post by: Snortin on April 22, 2014, 09:44:11 AM
Works great, Thank you Thomas for the quick customer support.   The big software guys should take pointers from you  ;)
Thanks again, Now I got to learn how to use this cool tool.
Jay
Post by: big-tex on May 02, 2014, 06:59:55 AM
your welcome
Post by: big-tex on June 18, 2014, 06:13:13 PM
Sorry everybody servers were hit with attack. All resolved
Post by: big-tex on December 06, 2014, 11:44:00 AM
Ok I am using new provider, website back up
Post by: big-tex on December 07, 2014, 06:27:17 PM
If anyone has questions please send me email using my website
Post by: rplayle on December 12, 2017, 07:47:21 PM
Hello, Im a newbie to the forum and hope this is the right place to post,
couldnt find anything under search on this issue
im running Big-tex Blue tool setter ver3.4 and just finding my way around it,
all seems good once I got past the - you have to set the tool change position Z or the "initial set up" is going to crash"
the problem im having is that anytime i click a button on any screen it disappears, it will reappear if i refresh the screen (minimize then maximize mach 3)
doesn't do this on the normal mach3 screen
running Windows 10 on an I5 machine, any ideas how to fix this ?
many thanks
example attached (machine coordinates button)
Post by: big-tex on December 13, 2017, 07:46:26 PM
PM sent
Post by: matterest on September 15, 2019, 09:44:37 AM
is the big tex screen set still available? if so, where?
thanks,
matt
Post by: ZASto on September 15, 2019, 11:53:18 AM
I don't know what happened with Thomas,exchanged a couple of e-mails withhim, but he did not fix his page :(
I've bought his screenset and I know where it is still obtainable, but it would be unfair to share that location.
Send Thomas an e-mail, will provide you his address through PM
Post by: Troncatore on November 16, 2019, 02:01:15 PM
Sorry I would like to download this screen set but the Link on the Artsoft download transfer me in another site...and if I would like to do the same on the other one blue it can't append..How I have to do the download?
Post by: Drew Riley on April 05, 2020, 04:24:11 PM
Anybody have a working link to the latest version of this screenset?
Post by: ZASto on April 06, 2020, 01:12:24 AM
This is a link to the version that I use.
It used to cost $20, so if anyone wish to use it, can send Thomas the $20 by PayPal.
https://drive.google.com/file/d/0B0cgFjjHPRt7bEwwNjEtYXZHd3M/view?ts=58c16811
Post by: Bluelight on April 28, 2022, 09:25:16 PM
I sent you a PM sir if you could pls check it. Thanks :)
Post by: ZASto on April 28, 2022, 11:46:05 PM
As the gdrive link is non functional, here is another that will stay for much longer.
Do not be afraid of russian language, I use that cloud service as it is cheap.
https://cloud.mail.ru/public/6mtg/2WYpmeTvD
Post by: Gvalenz07 on April 29, 2022, 10:34:36 AM
Where could I download this screenset. The link to big tex does not work. (Can not be found) Or can anyone recommend a screenset that can use "triple edge finder"?
Post by: Bluelight on April 30, 2022, 01:25:50 PM
Read above
