Mach Discussion => General Mach Discussion => Topic started by: markn on March 13, 2014, 08:59:10 PM
Gentlemen,
I have had a licensed copy of Mach3 on my computer for a number of years. I now would like to move the software and license to the PC that I am using for my Bridgeport retrofit. How do I accomplish this?
Just copy the file license.dat to the new machine.
It's Mach1Lic.dat
Your Mach3 license is called Mach1Lic.dat and it is in your original Mach3 folder - just copy and paste / transfer it to your new Mach3 folder and away you go (no need to purchase a new license).
If you wish, you can download the latest version of Mach3 from here http://www.machsupport.com/software/downloads-updates/
(originally contributed by our good friend Tweakie)
Russ
Quick draw McGerry :D
Russ
Thanks for the replies. When I copy the mach folder SETUP.EXE will not transfer over.
Hi
Has anyone experienced the issue with copying the setup.exe folder.
On my PC the folder appears faded compared to the folders in the Mach3 directory. I have the thumb drive plugged in paste the copy to it and I can see it. But when I transfer to the new PC the setup.exe file is not on the thumb drive..........
You shouldn't need any setup.exe file.
This is a fresh install on the BPort PC .. right ?
Download the version you prefer, save it then run it on your new pc. (from earlier link/FTP site)
Then add your .lic, custom screens, macros, brains, plugins and anything else from the old pc.
I don't think you can just copy the M3 folder to the new pc.
I could be wrong (again) though,
Russ
Hi guys.
I successfully downloaded and installed mach to the new PC. Now when I open mach the PC freezes. Any advice?
Whatare the specs of the PC what OS and what additional software do you have on it.
How far do you actualy get before things freeze?
Is this a new computer or an older one just new to this purpose?
Hi Hood
Newer used computer with no other programs. I don't have processor specs with me. OS is XP. Freezes when I open mach. Click on mill icon, starts to load and freezes up
Ok
Specs on pc; 600MGz 224mb ram
Software Requirements
Mach3 Minimum Recommended Requirements:
*Use of Parallel Port for machine control only on 32-bit versions of windows.
32-bit Desktop – Parallel Port Requirements
32-bit version of Windows 2000, Windows XP, Windows Vista, or Windows 7
1Ghz CPU
512MB RAM
Non-integrated Video Card with 32MB RAM(Large G-code files, especially 3D files will require a video card with 512MB RAM or higher)
From the Mach3 website.
Looks like you have one of Fred's old computers .... or maybe Barney's ? :)
Russ
Yeah. I looked a little earlier and realized the same thing. I bought this unit 6 years ago and child rearing took over. Just started to revisit the project after the Anilam Crusader picked out
