Mach Discussion => Mach Screens => Topic started by: BOHICAMAN on March 12, 2014, 02:08:54 PM
Title: G-CODE Button Problem
Post by: BOHICAMAN on March 12, 2014, 02:08:54 PM
I placed a Button on screen. Then I entered the text for it, "G-CODES". Next I clicked on the FUNCTION box in the MachScreen Properties Dialog box and selected "Execute Basic-Script" (this was the only Function listed in either OEM or Standard) that appeared even close to what I wanted to do). When I selected this Function, the Standard Code  box changed to 34. Also, LOADFILE (C:\Mach3\MillBitmaps\G-code_US.bmp) appeared in the Execute code box.
I want this button to open the file on screen that shows the list of G-Code numbers and their functions. (I plan on a similar button for M-Codes). When I save the Screen and load it into Mach3, when pushed, the button does nothing! The file called is spelled correctly and in the path listed in the Execute Code box. I have no idea why this will not work! Anybody got an idea???
Bob
Title: G-Code Button problem
Post by: BOHICAMAN on March 12, 2014, 02:35:42 PM
Disrecard my above post!
