Tangent Corner => Tangent Corner => Topic started by: Jimster on February 27, 2014, 05:14:05 AM
If I wanted to make something like this:
(http://paceperformance.com/images/M15197018.gif)
would it be possible on a 3 axis machine? how would I make the lip on the top of the pipe?
??? Mill outside profile, drill hole ,put it on arbor .
Stick turning tool in vise turn the rest .
It would be easer to turn it and then mill.
Good luck.
Chris
I had a mill cutter modified with a notch in the flutes to cut the lip.
Form tool, like garyhlucas described. A special tool, that is shaped to make a specific feature. Also,, yes, easier to turn it, then mill to finish. However,,, in aerospace, we mill perfectly round enough features like that,, with a 16 finish all day long,, on a regular old 3 axis industrial type machine. Im sure a bench top, or hobby machine can too, but accuracy and finish will not be aerospace standard!
