Mach Discussion => FAQs => Topic started by: shortyfrlife on February 21, 2014, 02:03:09 PM
Title: Mach 3 only loads half of the gcode
Post by: shortyfrlife on February 21, 2014, 02:03:09 PM
We got our cnc table set up and ready to go but every time we go to load a gcode into Mach and run it, it gets half done and then the code ends. I have no idea why, the company we bought our machine from thought it was a registration issue with the software so they sent us a new code but it is still happening.  ???
Any help would be greatly appreciated.
Mandy
Title: Re: Mach 3 only loads half of the gcode
Post by: ger21 on February 21, 2014, 04:04:39 PM
They shouldn't be sending you a new license if one doesn't work. Who'd you get the license from, and is there a name on the license?
Post by: shortyfrlife on February 21, 2014, 06:32:48 PM
We got our machine from Lightning CNC. The license was in the wrong folder so the program didn't recognize it. But we are still having issues loading the .tap files into Mach3. Some of them only half load others wont load at all then others load but are so tiny there is not way to use them.
Post by: ger21 on February 21, 2014, 11:21:00 PM
When they don't load, is there an error message?
Post one program that you're having trouble with and explain what the problem is with that particular program?
Post by: mikes welding on February 26, 2014, 12:15:05 PM
i am  having problems  with g code not cutting completey also  someone  told  me  to  check  the  mach  3 license to see  if it  is  demo  mode  or  my name  i bought  the  machaine  from  a  company  out of OK as  a package  deal the license  does  not  say  demo  but  it  does  not  have  my  name  there  someone  else
Post by: coenraad on May 27, 2015, 08:58:10 AM
Hi, Another new guy,
I am having problems loading demo files on mach3. it only loads half the code. Initially I thought it is the demo thing, so I bought a licence, My name shows up when I check in mach help menu. So it is licensed. Still the problem is there. So I uninstalled and re installed, no joy, still only loads half a file. What can the problem be. One of the files in question is the collet spanner file that comes with mach.
Post by: Tweakie.CNC on June 01, 2015, 11:42:49 AM
Did you purchase your license direct from Artsoft /NFS or from somewhere else ??
Post by: ryflores05 on August 23, 2015, 02:40:42 AM
i am having the same issues only a portion of the gcode loads up when I load it but that's when the parallel drivers are installed when i uninstall mach3 and install it again without the parallel driver then the entire gcode loads. Any help would be appreciated.
Post by: Tweakie.CNC on August 23, 2015, 06:20:15 AM
Without the licence file installed Mach3 operates in Demo mode. It will only run the first 500 lines of Gcode with the parallel port drivers installed - purchasing and installing the Mach3 license file removes this restriction.
Post by: lucan07 on March 29, 2016, 02:58:55 PM
Idiots curently selling pirated licences on eBay if anyone wants to get them removed
Post by: PapaBeechie on November 16, 2016, 08:39:25 AM
I to have the same problem with my system. It only cut 500 lines even though it is licensed, I bought the license from the mach3 website. It comes up as licensed with my name
but still only 500 lines. I can disable the port and it sets all lines but won't cut any thing. Enable and it runs as demo but it is licensed.
Post by: rcaffin on December 03, 2016, 09:53:24 PM
This is a licencing issue. Contact Artsoft.
Roger
Post by: Tweakie.CNC on December 04, 2016, 12:34:11 AM
This .pdf gives an explanation regarding license installation;  ftp://anonymous:guest@ftp.machsupport.com/Extra%20Information/Mach3%20License%20install%201.pdf (ftp://anonymous:guest@ftp.machsupport.com/Extra%20Information/Mach3%20License%20install%201.pdf)
Post by: rcaffin on December 04, 2016, 12:48:03 AM
Hey Tweakie - that URL does not work for me.
Roger
Post by: Tweakie.CNC on December 04, 2016, 02:41:27 AM
Hi Roger,
I was in two minds about posting it as ftp:// links work for some and not for others.  :'(
(You can get the .pdf by going to the .ftp downloads area http://www.machsupport.com/software/downloads-updates/ , it is listed under Extra Information).
Post by: rcaffin on December 04, 2016, 02:53:28 AM
The wheels sit there spinning, and spinning ...
But they never get there???
WXP SP3
Roger
Post by: Tweakie.CNC on December 06, 2016, 02:54:27 AM
WXP SP3
Roger
You could perhaps try resetting your DNS Server.
Post by: rcaffin on December 06, 2016, 03:29:37 AM
My system must be locking out whatever response the FTP side of things is getting. No idea why.
Maybe an adblocker and a cookie filter?
Roger
