Mach Discussion => General Mach Discussion => Topic started by: LexMotorsports on February 18, 2014, 04:09:09 PM
Hey guys,
I am having troubles with my geckoG540 board, my relay is not clicking when plugged in.
I changed the relay completely, but im just not 100% sure if the wires are wrong, or what,
If someone could help it would be greatly appreciated.
Would need a lot more info before we could even suggest what may be wrong.
For example where have you got the relay connected?
Do you have the correct port and pin numbers assigned?
How are you switching the relay from Mach, ie is it for the spindle or something else?
Are you hooking it up for the first time or did it quit working?
