Mach Discussion => General Mach Discussion => Topic started by: iohan on February 16, 2014, 07:55:05 AM
Hi, i'm new to this forum.
I have a problem setting up Proma THC with Mach3 and thought maybe some of u could help me resolve it.
I have installed the Proma THC correctly and while running testmode on the THC i see the yellow lights flash (THC UP/DOWN) in mach3 diagnostics.
My problem is that the Z-axis doesn't move from the inputs of the THC. I can jog the Z-axis with the keyboard.
Anyone know a solution to why Mach3 doesn't move Z-axis while it clearly gets input to do so?
Thank U!
hi mate im having the same problem just woundering if you sorted it out and would have any info
Do you have properly licensed Mach3 install??
THC only works on this.
yeh mate I have got movment now but highly doubt iv done the right thing I'm sort of guessing a lot, I cant express just how green I am at all this. but I went into -ports and pins- -inputs- and right down the bottom where it says jog z axis up and down I set the same pin numbers that my THC sends to . what do you reckon is that loco!!!
It **might** but I don't think you will find a Jog move is anything like a THC move - jogs use acceleration/deceleration curves, THC does not, it's just bang up, bang down and needs that due to the tiny window of time it has to operate in - the torch does not stop while the THC is adjusting the height, this is why we have the THC rate DRO - because you cannot bang an axis up and down at speed without accelerating it first so you have to use a percentage of the speed that DOES allow you to bang it up and down - usually around 20%
yeh I figure as much, I have a full version and (allow THC) in mill settings is checked and the box THC in (plugin config ESS-v10hd2) . do I need to have anything checked in output signals , the machine runs well and I have cut a few things but just cant get this THC to respond , the THC input signals are set on active low and I can see them in the diagnostics screen
Cant help with the ESS as I'm on parallel port here, no as long as you can jog the Z with the PgUp / PgDn keys on the keyboard there is no output to set.
Have you got an "Arc-Ok" signal? If yes then the "Allow THC when not in THC mode" should be unchecked I think.
Do you have a value in the THC rate DRO on the settings tab? Try 20% to start with.
You could try going into ports and pins, inputs, and flipping on "Emulated" for THC-Up & THC-Down, just for a test, this should allow you to kick the z up/down with the keyboard by pressing U & D respectively, may have to set that 'allow thc when not in thc mode' back to on to do this but put it all back afterwards.
groovy I will give it all a try and see what happens
