Mach Discussion => General Mach Discussion => Topic started by: vladimir059 on March 08, 2007, 05:01:26 AM
Title: set up for two different machines
Post by: vladimir059 on March 08, 2007, 05:01:26 AM
Hello Everybody!
I’m going to build another CNC machine, and I’d like to control both machines by the same Mach 3 software  . My question, is it possibly easily change set up between two machines? The machines have absolutely different controllers, lead screw, purpose and so on. Can I change set up during start up of Mach 3?
Thank you in advance
Vladimir
Title: Re: set up for two different machines
Post by: Chaoticone on March 08, 2007, 07:52:30 AM
Vladimir,
    What do you use the two machines for?
Post by: rcrabb on March 08, 2007, 08:46:44 AM
If your only running one at a time I would think its very easy. Create a setup for each machine. Load the profile (or XML file) for the machine you intend to run. This is done when you open mach and are promted to select a different profile. Each different XML file in the mach directory will be a different profile you can choose. Hope this helps.
Post by: vladimir059 on March 08, 2007, 12:25:49 PM
Hello Brett .
I already have 4 axis CNC mill machine and I'm going to build 3 axis CNC PCB engraver. Now I'm using CNC mill for PCB engraving, but due to table restrictions and slow speed of axis I'm looking for another solution. I will use one machine at time.
Vladimir
Post by: vladimir059 on March 08, 2007, 12:28:29 PM
Hello Ryan. Thank you for reply.
I will try to use different profile during start up procedure.
Thanks again
Vladimir
