Mach Discussion => Mach Screens => Machscreen Screen Designer => Topic started by: kjlpdx on February 05, 2014, 01:02:04 PM
I wanted to change the SOFT LIMITS button to light red when the limits weren't in effect. I got it to become a red/green LED but it lit red when I wanted it to be green. so I went back and switched it to a red LED, but that didn't make a difference, off is still green and on is red, the opposite of what I wanted. what controls the way the red/green works?
Doesn't look like you got much help yet! I have same question. I played with it for a few hours and still don't see a way to change it. Did you have any luck>
Bob
I haven't messed with it more. someone wrote that I could make it a user defined LED and write some script to run it. it still makes no sense to me that this isn't just a flipflop type of switch variable.. I seem to remember the system returns 0 or -1 to make it red/green. you'd think that there would be a definition of red/green and another as green/red, but I can't seem to make that happen.
Guess I'll have to learn more about Scripting!
You don't need any scripting. Just create a new LED image as you want it to be and select it.
