Mach Discussion => General Mach Discussion => Topic started by: katadhin on January 13, 2014, 01:04:31 PM
Title: checking jogging voltage pins
Post by: katadhin on January 13, 2014, 01:04:31 PM
I need help in checking the Y axis jogging pin to check the voltage. when i jog it down arrow key it goes up, the up arrow key goes up.
thanks rod
Title: Re: checking jogging voltage pins
Post by: Hood on January 13, 2014, 02:50:48 PM
Change the active state of the Y's Dir pin, in Ports and Pins, Motor Setup.
