Mach Discussion => General Mach Discussion => Topic started by: Scott Pancheau on January 09, 2014, 07:23:35 PM
Title: Mach 3 with Heidenhain Control
Post by: Scott Pancheau on January 09, 2014, 07:23:35 PM
I have acquired a Bridgeport mill with a heidenhain control. I am wondering if there is a post proccessor for the code generated by mach and lazy cam to feed needed form of ISO code to control. It seems to have a lot of different g code meanings and a diff. way to define arcs than mach. I can just use a dnc program with a few macros to feed mach code into my allen bradley and it works great but not so with heidenhain. Any help appreciated.
Title: Re: Mach 3 with Heidenhain Control
Post by: RICH on January 10, 2014, 06:35:00 AM
I have not seen any PP info to modify it for LazyCam as LC is what it is  and may be better to use different software. See Page 32 in the Lazycam Manual which can be found in Member's Doc's as LC program options along with how Mach is configured is used for gcode output. I don't know the differences in gcode between Heidenhain and Mach but as you stated and as shown on page 32 what gcode produced for the Heidenhain controller must be appropriate.
Post by: Scott Pancheau on January 10, 2014, 08:19:34 AM
Thank you Rich. Guess that is why I came up empty searching on line and in forums. The man I purchased it from uses visual mill and I think he developed his own PP. He said he would help get me up if I bought that same program. It is reasonable priced but way more than Mach and I love Mach after using it for some tiime. I am really a slow learner on code variables, and he indicated the program has a kinda steep learning curve.
Thanks Again
Post by: Hood on January 10, 2014, 12:46:06 PM
Mach is a controller, it is not for producing code, so no post processor for Mach.
Post by: Scott Pancheau on January 11, 2014, 09:40:19 PM
Thank you Hood,
Scott
Post by: Hood on January 12, 2014, 02:49:27 AM
I have looked and BobCAD has a load of PP's for use with Heidenhain,  Dolphin has some as well, whether they are for the model you have or even how well they work I have no idea. It is however two CAMs you can look at.
Post by: Scott Pancheau on January 13, 2014, 03:32:11 PM
Thanks again Hood. I am in the process now of evaluating some options.
