Mach Discussion => General Mach Discussion => Topic started by: comet on March 05, 2007, 04:13:55 PM
I have noticed eratic linear moves on both of my machines if the feed rare increases over 600mm pm.
they dont miss steps but kind of stops and waits for more pulses,I am 100% sure its software related
any Ideas?
Tony
Check to see if enhanced pulseing is enabled.
hi Hood
yes it is enabled on both machines.
the problem is more noticable on my router,its running at 115 steps per mm with a max of
3000.
the computer is a 1.8 p4 with xp and 256 of ram using a pci parallel port
tony
Run the Driver test and see if you get a good graph
Brian,
ran the test and there seems to be a "fuzz" for a couple of seconds
then off for acouple of seconds then on again.
Ive not seen one this noisey before.
Tried taskmanager and theres nothing using cpu there.
its a clean install of xp pro,mach3v53 with mastercam, a wireless usb network device (makes no diference with this unplugged) and a program that came with my webcam.
Any Ideas?
As an aside is xp home a better system to set mach3 up on because it hasent got all the
network bells and whistles?
Tony
Open MSconfig and uncheck all the programs that would like to load at Startup.
Brian,
I have done that,there is something ticking away in the background,
not sure what though.
Tony
My set up did not like the wireless network at all.
Guys,
the hard black band of "fuzz" is between approx 36-42us 2 seconds on 2 seconds off.
if i have the usb wireless dongle plugged or unplugged,from start up it still makes no differance?
any I deas?
Tony
Hey Tony,
I don't know if you have looked at this thread but it may help your problem. Look at the reply from Art.
http://www.machsupport.com/forum/index.php?topic=1381.0;topicseen
