Third party software and hardware support forums. => Newfangled Mill Wizard => Topic started by: Doddy on January 02, 2014, 04:35:20 AM
I bought/registered MillWizard today, having taken a step into CNC over Christmas, and wanting a SIMPLE utility to allow GCode to be quickly and easily created.
I've created a project to cut a rectangular shape from a piece of perspex, thinking that I'd created suitable feed and plunge settings (800mm/min, 60mm/min, respectively). What happens with the generated g-code is that the feed rate is set correctly for the plunge, but never set again for the x/y feed, resulting in a very slow x/y feed into the work (which, with perspex, is likely to burn the stock material). G-Code extract given below with the plunge feed-rate highlighted (*****) :-
(MillWizard 1.0.13)
Any clue as to what I'm doing wrong?
(***New File Started***)
(created by NFS Mill, V4)
(New File Started 01/02/14 09:42:40)
(posted for Perspex3mm )
(Strategy: As Entered)
(Rapid height: 1.0000 Clearance height: 1.0000 )
G98 G80 G17 G90 G54 G64 G91.1
G21 G90
(***New Tool Selected***)
(ToolNum: 02 Diameter: 2.3825 )
(Feed: 800.0000 SFM: 168.0000 Plunge: 60.0000 ChipLoad: 0.0318 )
M9
M5
M06 T2 (Green CornCob)
G43 H2
M03 S16843
(***Cut Rectangle***)
(Xorign: 0.0000 Yorign: 0.0000 Length 200.0000 Width: 160.0000 CorR: 0.3000 InOut: 01 )
(Ztop: 0.0000 Zdepth: -2.9000 Zstep: 1.0000 )
(will make 3.9000 cuts of: 1.0000 )
G00 Z1.0000
X0.3000 Y162.6208
X-0.8913
G01 Z-1.0000 F60.00 (*************** FEED SET HERE ****************)
X-2.0825
G03 X-0.8913 Y161.1913 I1.1671 J-0.2385
G01 X200.8913
G02 X201.1913 Y160.8913 I0.0000 J-0.3000
G01 Y-0.8913
G02 X200.8913 Y-1.1913 I-0.3000 J-0.0000
G01 X-0.8913
G02 X-1.1913 Y-0.8913 I-0.0000 J0.3000
G01 Y160.8913
G02 X-0.8913 Y161.1913 I0.3000 J0.0000
G03 X0.3000 Y162.6208 I0.0241 J1.1910
G00
Z1.0000
X-0.8913
G01 Z-2.0000
Please save and post here a job file, that way I can see exactly what entries you made.
Job file attached (hopefully... 2nd attempt)
Hmm, I can't see the attachment even though the forum software confirmed it's attached. In any case, the content of the job file is
1|1|Job|C:\Program Files\NFS_Mill\ToolTable\baseplate.tap|Perspex3mm|5|260.0000|325.0000|550.0000|750.0000||1| As Entered|1|1.0000|1.0000|C:\Program Files\NFS_Mill\ToolTable\Doddy.wtl|30000.0000|800.0000|60.0000
2|1|TOOL|2|2.3825|0.0938|0|4|2|168.0000|0.0238|22445.0000|800.0000|60.0000|0|0|0.0000|Green CornCob
6|1|RECTANGLE|0.0000|0.0000|200.0000|160.0000|0.3000|0|3|1|0.0000|-2.9000|1.0000|0.0000
6|1|RECTANGLE|0.0000|0.0000|20.0000|3.0000|0.0000|0|3|0|0.0000|-2.9000|0.5000|0.0000
6|1|RECTANGLE|180.0000|0.0000|20.0000|3.0000|0.0000|0|3|0|0.0000|-2.9000|0.5000|0.0000
6|1|RECTANGLE|0.0000|157.0000|20.0000|3.0000|0.0000|0|3|0|0.0000|-2.9000|0.5000|0.0000
6|1|RECTANGLE|180.0000|157.0000|20.0000|3.0000|0.0000|0|3|0|0.0000|-2.9000|0.5000|0.0000
6|1|RECTANGLE|0.0000|0.0000|3.0000|20.0000|0.0000|0|3|0|0.0000|-2.9000|0.5000|0.0000
6|1|RECTANGLE|0.0000|140.0000|3.0000|20.0000|0.0000|0|3|0|0.0000|-2.9000|0.5000|0.0000
6|1|RECTANGLE|197.0000|0.0000|3.0000|20.0000|0.0000|0|3|0|0.0000|-2.9000|0.5000|0.0000
6|1|RECTANGLE|197.0000|140.0000|3.0000|20.0000|0.0000|0|3|0|0.0000|-2.9000|0.5000|0.0000
with the wtl content:-
1|Orange CornCob|0.1250|4|0|0.0000|0
2|Green CornCob|0.0938|4|2|0.0000|0
Ok, looks like a bug when you do a plunge cut instead of a ramp into the work. If you change the ramp angle on the tool settings to something like 5 it all works fine.
I will have to find this one and fix it and make a new release. That will take at least a few days.
I notice you are using Rapid Height and Clearance as the same value. Do you understand that Rapid is the height above all clamps where rapid moves are allowed. Clearance is the height that a plunge will stop moving at rapid speed and switch to plunge rate. It is also the height to raise the tool between passes. Using the same value is OK, just not using one of the wizard features.
Re. workaround - thanks - I'll give that a try (a quick look at the generated g-code looks good).
Re. rapid/clearance heights - thanks for the info... that'll probably save a few cutting bits, although I'm still in the what-am-i-doing phase, it's probably a good idea to get into good habits earlier, than later.
Many thanks.
