Mach Discussion => General Mach Discussion => Topic started by: jaustin on December 25, 2013, 05:53:28 PM
Title: Bunch of circles in my preview window?
Post by: jaustin on December 25, 2013, 05:53:28 PM
Not sure what to call it but if you look at the attached image it is the pink lines in the window.
Run it thru the Discriminator CNC Editor it runs good(to me  since I am still learning)
I think I might have something set wrong in Mach3.
Anyone have any ideas on what is causing the pink areas?
Title: Re: Bunch of circles in my preview window?
Post by: jaustin on December 25, 2013, 05:54:08 PM
other image
Post by: Picengraver on December 25, 2013, 06:49:24 PM
Reverse your IJ mode - Gen. Config.
Merry Christmas,
John Champlain
Post by: jaustin on December 25, 2013, 06:58:41 PM
Thank you I set it to Inc.
What does IJ mode do?
Post by: ger21 on December 25, 2013, 07:01:18 PM
Specifies how the center point of arcs are defined.
Post by: jaustin on December 25, 2013, 08:04:52 PM
Will I ever need to reverse again?
Post by: ger21 on December 25, 2013, 08:28:04 PM
Only if you use code that uses absolute IJ mode.
