Mach Discussion => General Mach Discussion => Topic started by: pofo on December 23, 2013, 04:23:17 PM
I have Z home enabled. X and Y are disabled. I have soft limits of +/-100,000. The input switch is not active.
I hit the Ref All Home button and the Z axis moves +.200 and stops. The Z DRO resets to whatever the initial value was. That is, if it started at -2.00, it travels .2, stops @-1.8 and resets the DRO to -2.00. No error message.
What am I doing wrong?
In Config >Homing/Limits, do you have a Home Offset of -2?
If so, then noise is probably triggering your switch.
The home offsett is zero. I don't think it is noise as the behavior is consistent. I can have the Z anywhere on its travel and have the DRO set to any number. It always moves +.2 and stops.
please attach your xml.
Thanks for the offer Hood. It was operator error. The button had the legacy DoButton code. I switched it to DoOEMButton and it worked.
Strange the DoButtons should work fine but as long as you have it working thats all that matters :)
It's running through a DSPMC. That may have something to do with it.
ah ok. Is it version 066 of Mach by any chance?
Yes, it is R3.043.066
Well there are known issues with it and homing, most likely when using external controllers. I have gone back to 056 or 057 .
