Mach Discussion => VB and the development of wizards => Topic started by: nso on December 20, 2013, 12:45:51 PM
Title: encoder dro with m/c dro Comparison
Post by: nso on December 20, 2013, 12:45:51 PM
is it possible check( encoder dro )and( machine coordinate dro)
have some deviation during just mach3 do E-stop ?
i need to know can do this with macro pump or Brian.
if any one can  advise to me make me happy...
thanks
Title: Re: encoder dro with m/c dro Comparison
Post by: cncalex on December 20, 2013, 03:11:29 PM
this one may be worth a try.
see pict.
Post by: Bodini on December 20, 2013, 05:51:10 PM
If you are just looking to see the deviation error, check OEMDRO's 127, 128, 129.
Error between Encoder 1 and abs X position DRO   127
Error between Encoder 2 and abs Y position DRO   128
Error between Encoder 3 and abs Z position DRO   129
Post by: nso on December 20, 2013, 11:26:10 PM
first of all i say thanks guys for quick reply...  :)
cncalex ;i tried  today if work or not say here .
Bodini : it just dro for Error between Encoder ,so i need this:
if have a  deviation error on each axis then active output ,or do oem button  reset. thanks again
Post by: cncalex on December 21, 2013, 06:20:36 PM
Is this closer to what you want ?
alex
Post by: nso on December 21, 2013, 10:44:12 PM
i tried right now and yes that is working great thanks.
yesterday i tried something like this with brain . it is working like your brain, but in your brain better....
now i have a new problem :
in this case i use servo motor encoder on my machine and encoder pulse = 2500 per revoltion
i guess mach3 can not reading pulse maybe encoder pulse is too fast or big ?!!! ???
when axis moving slow dro encoder pulse is true but during axis moving like G0 then encoder dro false
how can solved this problem?
sorry for my bad english
Post by: cncalex on December 22, 2013, 06:56:26 AM
If after a rapid move the axis position and encoder position are the same then it looks like yor problem is the follow error of the servo.
in this case you can try tu tune the servo more stiff. Or increase the allowable lag in the Brain.
If after a rapid move the axis position and encoder position are completely different then I think the pulses came too fast.
no prob., my is not even better  ;D
alex
Post by: BR549 on December 22, 2013, 08:27:33 AM
One of the problems you run into doing this is it takes a LOT of CPU resources to read all the encoders at speed. Mach3 is not really up to do this reliably. The OEM (Rogers Machine) that has done this USED a seperate high speed counting board to COUNT the encoders and report to Mach3 via a plugin. This takes the load off of mach3 and it works fine. You can EVEN have mach3 auto correct the position if it gets off track.
Just a thought, (;-)TP
Post by: nso on December 22, 2013, 11:39:55 AM
dear cncalex , i am sure  my servo motor and drive is tuning correct ...so perhaps encoder pulse too fast because 2500 per r
if  use (1000 per r or less) encoder  then possible solved this problem?
BR549 hi,thanks for replay i see rogers website and i know how to work...i can t buy that (from my country)  :-\
so i tried find result and i know maybe cant do that but just tried...
Post by: cncalex on December 22, 2013, 06:43:12 PM
AFTER a long rapid move is there a difference between the axis dro and encoder dro?
alex
Post by: nso on December 22, 2013, 10:39:03 PM
yes exactly true .... for example : when move axis rapid ,230 mm then dro show true but encoder show 237,234,236 in fact random ...
Post by: cncalex on December 23, 2013, 06:01:56 AM
Ok, in this case I would say yes. You said you get nice results at half rapid speed then reducing the encoder resolution ( PPR) should work.
But as TP said your system will have lot of work to read the inputs.
For that I would choose the lowest encoder resolution where you can live with lets say 400 PPR or lower.
Alex
Post by: nso on December 23, 2013, 09:32:34 AM
thanks dear friend ,you kind of to me ,so your comment is my result ... after see your last reply, i searching at pdf of servo drive manual about
decrease encoder pulse, and i find a parameter can change ratio pulse output i guess may can help me but i don't try yet...  ;D
Post by: Bodini on December 23, 2013, 10:34:37 AM
Elaborating on what TP said, I will give you a few more clues.  Rogers encoder board uses a plug-in.  Brains or VB/macropump just arent fast enough to monitor closed loop with much success.  The plug-in compares steps sent by Mach to counts sent back from encoders.  It doesnt use DROs at all, but rather the raw data behind the scenes in Mach.  The encoder board is the only way Mach can read and compare it all fast enough.
However, if you are having any sort of luck at all, I encourage you to keep pushing and see what you can get it to do! :-)
Post by: nso on December 23, 2013, 12:01:43 PM
Bodini ,thanks for your support...
Post by: cncalex on December 23, 2013, 12:44:48 PM
I assume you want it for a kind of safty, if something fails to e stop the system.
a kind of closed loop isn't possible with a brain ( or macro ) not even close to.
the brain runs fix at 10HZ  so 100ms for one run.
that means you have a lag of 1mm at 600mm feedrate or 10mm at 6000mm feedrate and so on.
plus the lag time of the incoming pulses what is small compared to the brain.
Alex
Post by: nso on December 23, 2013, 10:24:47 PM
Alex ,you right... i tried with 0.1 mm lag error at 2000 mm feed rate the 9 mm !! so that is too big and i looking for less like( 0.2 or 0.3 mm) maximum  in this case i take my answer with your advise ,in fact can t do this just because brain & macro too slow...
anyway i want say thank you and other  :)
