Mach Discussion => General Mach Discussion => Topic started by: Genes1s on December 13, 2013, 11:27:09 PM
Hi guys,
I'm totally new here and recently got the G0704 running with Mach3 and MasterCAM V9.
In the MC 9, I devided the tool path into sections hoping that I can stop at the end of the each cycle to change the end mill (2 flutes to 4 flutes, etc) or re-clamp certain area. How do I do this when the machine is running in Mach3? I tried using pause, but couldn't pause it at certain location.
MasterCAM Tool path.
(http://i1117.photobucket.com/albums/k589/GenesisLights/Mobile%20Uploads/image-7.jpg) (http://s1117.photobucket.com/user/GenesisLights/media/Mobile%20Uploads/image-7.jpg.html)
(http://i1117.photobucket.com/albums/k589/GenesisLights/Mobile%20Uploads/image-8.jpg) (http://s1117.photobucket.com/user/GenesisLights/media/Mobile%20Uploads/image-8.jpg.html)
The tool is the same for each step.
Program in a tool change for each step. Mach3 will stop and ask for a new tool each time
Thanks! That makes sense. That would stop the cycle and prompt for "cycle start" even though I plan to use the same tool.
The way that do things is to generate separate GCode file for each operation.
The machine that I'm sunning at the moment is a Chinese one with a pendant controller (Ti DSP inside) which is dumb enough, i.e. not interpreting all G codes well (broke some drills during G8x canned cycles) and at the moment I'm designing a BOB to dump the existing controller and to connect it to 'puter and drive it with Mach3.
