Mach Discussion => General Mach Discussion => Topic started by: mgamber on December 11, 2013, 10:41:34 AM
Title: Display value of Gcode variable on a DRO
Post by: mgamber on December 11, 2013, 10:41:34 AM
Is there a standard code to put in the screen designer DRO to display a variable value that will be set via gcode #var?
Title: Re: Display value of Gcode variable on a DRO
Post by: HimyKabibble on December 11, 2013, 10:53:34 AM
Not sure if there is an automatic way to do that, but you could always do it with a macropump.
Post by: BR549 on December 11, 2013, 04:33:13 PM
There ARE some Dros that are cross linked to Vars I will try to look it up for you.
Rays way works for sure.
Post by: BR549 on December 11, 2013, 04:49:44 PM
Here is the scoop, enter a value into either side and you will see the value on the opposite side of the cross link.
#Vars  15001 - 15255
are cross linked with
User Dros 1001 - 1255
(;-)TP
