Mach Discussion => General Mach Discussion => Topic started by: kolias on November 30, 2013, 09:30:56 PM
Title: How have you installed your DB25 in your Panel?
Post by: kolias on November 30, 2013, 09:30:56 PM
Is there an easy way to have the big DB25 cable not shown inside your panel?
I was thinking to make a slot on the side / back of my panel and bolt the BOB into it and that will be the end of it but by doing so the BOB will stick out inside the panel and be prone to damage plus all the wiring to it will not look tidy
Perhaps there is a better way?
Title: Re: How have you installed your DB25 in your Panel?
Post by: magicniner on December 01, 2013, 05:50:30 PM
If it's inside the panel and appropriately supported I can't see it being prone to damage,  How tidy the wiring is will be entirely under your control, tywraps, suitable supports and well ordered cable routing can make the most impractical situations safe, tidy and neat.
Post by: kolias on December 01, 2013, 06:46:09 PM
No problem, I can manage fine but I was just looking if someone had a unique idea about the DB25 cable
