Third party software and hardware support forums. => Newfangled Mill Wizard => Topic started by: Monafly on November 25, 2013, 06:27:51 PM
Title: Arc slot problems
Post by: Monafly on November 25, 2013, 06:27:51 PM
The attached job file (Burley boss 500end) shows up an issue when I try to change the arc slot settings. They are currently start -90 and arc 180, but that puts it on the wrong side, I really need start 90, arc 180, but changing the start locks up the program.
In addition, when playing around with settings the second and third attached files (90 and 270) shows what I think is a problem. If I have start 0 and arc 90 it goes from 3 o'clock to 12 o'clock, but with start 0 and arc -90 it should go 90 degrees from 3 o'clock to 6 o'clock, but instead it goes from 3 to 6 via 270 degrees.
Thanks.
Title: Re: Arc slot problems
Post by: Ron Ginger on November 25, 2013, 07:44:08 PM
The problem of locking up on a 90 to 180 arc was reported and fixed a while ago,in V1.0.14 I just checked and Brian has not pushed that version to the web- it is still on 1.0.13  I will send Brian a note to get that updated.
I will check the other cases you describe.
Post by: Monafly on November 25, 2013, 11:24:42 PM
I had just downloaded and got version 1.0.13, so hopefully when the latest one is available the first issue will be solved.
