Mach Discussion => General Mach Discussion => Topic started by: dikkieduk on November 08, 2013, 05:36:05 AM
Title: erratic behaviour after customizing screen
Post by: dikkieduk on November 08, 2013, 05:36:05 AM
Hi All,
A friend helped me customizing my Machturn screen , sometime after that my steppers started acting in a strange erratic way.
After some experimenting it shows that running a program in the customised screen caused erratic steppers  but running the same program while in the diagnostics screen my steppers are behaving ok.
This is out of our league , i have attached  my screenfile can somebody please  help  out???
Thanks   Mark
Title: Re: erratic behaviour after customizing screen
Post by: Hood on November 08, 2013, 07:35:03 AM
Cant see how a screenset could make your steppers misbehave.
Post by: dikkieduk on November 08, 2013, 08:19:56 AM
Hi Hood thanks for your reply :  its absolutely true, if i change screens or run from diagnostic screen everything is ok.
Post by: Picengraver on November 08, 2013, 12:01:43 PM
Pardon the question, but are you changing screen views, or profiles?
John Champlain
Post by: dikkieduk on November 08, 2013, 12:41:48 PM
Hi John,
No change in profiles , i just load my cncprogram into Machturn , when i run it in my customscreen my steppers go erratic,
when i change screenview into diagnostics everything runs ok.
Mark
Post by: Hood on November 08, 2013, 02:57:22 PM
The only thing I could possibly think of that would cause a screen to affect the steppers is if the screen is very graphic intensive and your computers graphics card is very weak.
Post by: dikkieduk on November 09, 2013, 02:28:47 AM
Well Hood, In fact my graphics are actually a bit on the weak size , is there a way i can test if this is the cause (other than changing my computerhardware)  ??
Post by: Hood on November 09, 2013, 04:35:09 AM
You could try either adding a button to disable toolpath view or temporarily remove the toolpath view from your screenset.
Post by: dikkieduk on November 10, 2013, 12:56:33 AM
Thanks Hood , will try that
Post by: ger21 on November 11, 2013, 07:02:24 AM
If you have a very large toolpath display and a weak PC, that could be the issue. Try turning off the toolpath and see if it helps.
A few users of my 2010 Screenset had a similar issue. (about .1%)
