G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Campervankits on October 23, 2013, 03:30:38 AM
Title: Aspire to Mach3. Problems with Aspire tool path in Mach3
Post by: Campervankits on October 23, 2013, 03:30:38 AM
Hello to every one, my name is Mirko and i am a new user ;D
I am running a 2"x 2" cnc from a german manufacturer with a controller and software called NC easy.
As a drawing program i am using Aspire 3.0
After my original cnc controller broke down i decided to get my machine up to date.
I changed all 3 stepper motors and set up an ethernet smooth stepper After a few small problems all went well with installation.
Yesterday i made a my first cut out with mach3 but i discovered a problem with partly missing tool path from my aspire drawing.
What i did:
1.) generating the tool path in aspire (different tools) and export them with the mach3 post processor (Mach2/3 ATC Arcs(mm) to a folder and saved it as a .TXT
2.) Load G code into mach3.
There are parts of the tool path and parts of some drawings missing. It does not happen if i separate the tool path in aspire (one tool only) and export them.
I hope someone can help me to solve this problem.
Many thanks
Mirko
Title: Re: Aspire to Mach3. Problems with Aspire tool path in Mach3
Post by: ger21 on October 23, 2013, 06:18:18 AM
Do you have a licensed version of Mach3? Sounds like you may be seeing the demo limit of 500 lines of g-code??
Post by: Campervankits on October 23, 2013, 08:52:22 AM
That could probably be the problem. I bought a laptop including Mach3 already installed. How can i tell if its a licensed version?
Thank you for your help!
Post by: ger21 on October 23, 2013, 09:40:29 AM
Your'e name should be displayed in the title bar, or in the Help>about window.
Post by: Campervankits on October 23, 2013, 10:41:08 AM
Ok here is the problem it is a demo version. Thank you very much for your help.
Do you know how i can save the system settings when i switch to a full version?
Post by: ger21 on October 23, 2013, 10:53:55 AM
Nothing changes when you purchase a license. You just copy a license file into the Mach3 folder.
Post by: lazy mark on October 29, 2013, 07:40:00 PM
hi guys I would just like to say thank you for all your help I have now built 3 cnc machines; cnc hot wire foam cutter and two cnc routers
I have a question I cut some braces for a quadcopterout of carbon fibre sheet, when I view the image on mach3 it looks perfect but when I cut the part the letters are reversed so I am actually cutting the part upside down so the image I see on screen is face down on my machine bed
I am using vectric 2D
what am I doing wrong
https://www.facebook.com/coulsdon.cnc
many thanks mark
Post by: ger21 on October 29, 2013, 08:15:24 PM
Your Y axis is backwards.
Post by: lazy mark on October 30, 2013, 02:52:27 AM
thanks Gerry
lol whats the saying   CAN'T SEE THE WOOD FOR THE TREES
cheers mate
