Mach Discussion => General Mach Discussion => Topic started by: howard on October 21, 2013, 11:44:11 AM
Title: gcodes veering to the right when cutting return to zero is off that amount
Post by: howard on October 21, 2013, 11:44:11 AM
cutting holes wants to veere to right every time 1/16 then to 1/8 when back to zero its off that amount have to zero every time help please
mach3 with axyz 4008 table
Title: Re: gcodes veering to the right when cutting return to zero is off that amount
Post by: Hood on October 22, 2013, 09:30:44 AM
Not really sure what you are meaning, it could either be backlash or missing steps. However as you say you have to re-zero then it sounds more like missed steps.
Post by: howard on October 22, 2013, 10:04:03 AM
I put 2*3.5 vinyl rail to route pkt holes the more holes I route the more my hole are routed to the. Right of center whatever my holes are off my home is off the same amount and it is consistent. Y axis only to the right tuned motor different settings. And recalibrated!
Post by: Hood on October 22, 2013, 12:48:33 PM
Well I am not really clear on what you are trying to explain but if I understand it does sound like you are losing steps. Try increasing the pulse width to 10 and reducing your acceleration and velocity by 50% and see if that helps.
