G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: leerichmond on September 12, 2013, 03:19:43 PM
this is the g code from mach 3
should it not run at 250?
it runs at like 1.93? I run past g codes and they work fine
it shows federate of 250 in mach 3 but does not run it
N0001 (Filename: circle gav.tap)
N0011 (Post processor: Mach3 plasma.scpost)
N0021 (Date: 12/09/2013)
N0031 G20 (Units: Inches)
N0041 G53 G90 G91.1 G40
N0051 F1
N0061 S500
N0071 (Part: circle gav)
N0081 (Operation: Outside Offset, LAYER1, T2: Jet tool)
N0091 M06 T2 F250.0 (Jet tool)
N0101 G00 Z0.3937
N0111 X1.9688 Y-0.2796
N0121 Z0.1181
N0131 M03
N0141 G04 P0.02
N0151 G01 Z0.0591 F3.937
N0161 Y-0.0296 F250.0
N0171 G03 X1.9687 Y-0.0296 I-0.0000 J1.9983
N0181 G01 X1.9688 Y-0.2796
N0191 M05
N0201 G00 Z0.3937
N0211 M05 M30
IF you look on line # N0151 you will see that the GCODE tells mach3 to slow down to F3.937.
That would be 3.937 INCHES per min, SLOW.
Looks like you have the wrong feedrate set in sheetcam for THAT tool#.
the next line goes back to 250
I'd seen this happen to from time to time with some of my runs, not sure why mach was doing it so I had to change my post to output feed rates on all g1 moves. Just thought it was another quirk with mach. Very exciting when it took off at rapid rate during what should have been a feed move. For awhile I had the rapid override set and turned on to a feed rate that would save me from cussing.
YEP running blind eyed today. What version of Mach3 are you running??
could step back a couple, but the Smooth Stepper E works well with it and I hate fighting that battle again, lol might just have to.
Also the same version running with the Dynomotion Kflop/Kanalog, so that might be the issue. Does it on both machines.
OK I just ran into that as well do a sub routine RUNNING with the LPT driver. V.067
ONLY on G1 it was ok and with G2 it ran at rapid speed regardless of the F###
Just a s a note YOUR code runs fine here.
Can someone help me? I'm retired and bought a Cheap Chinese 3040 CNC router. It was running fine I did two nice name plates with it. Don't know what happen but the G-code fonts got small and the display window does not show the project in the correct size. Checked all my pin & port setting nothing has changed. So I uninstalled Mach 3 and reloaded the program
Same thing is going on. In settings I run inches the X,Y,Z all move 1". Load the G code and the same thing. Project is so small you can not see it on the display. Under last wizard box a yellow box says Abnormal condition I J mode absolute. So I downloaded Mack 3 trial version again and installed it and everything is the same. HELP
Hi Farv,
Welcome.
If your machine is set-up in Inch units and the Gcode file you are using has been compiled in Millimetre units then everything will be small unless...
Use Notepad to edit your Gcode file to add G21 (on a new line) at the start of the Gcode listing. This tells Mach3 that the file is in mm units and it will then scale the axis movements to match your machine units setup (hopefully).
Hi Tweakie.
Thank you so much for your reply. My projects are in inches and this is the way I have Mach 3 set up. I did try entering G21 just to make sure. Nothing has change. As soon as I can figure out how to do it I will upload a photo of my screen. In my diagnostic screen when I push the up arrow key I do not see any LED's light up, only when I set the E stop. Also in Port 1 pins current state I have 5 LED's in the upper row showing green.
Don't put too much faith in that, the Port 1 Pins Current State does not always work as it was intended.
Another thing to remember is that the G21 /G20 commands are Modal. (all good Gcode files will always declare G21/G20 as appropriate).
Still no luck.
Good afternoon Tweakie. Last night I uninstalled Mach 3 and reinstalled it. Loaded a G code file that I used before with no problems The project shows up in the display screen so small you cant hardly see it. I run the axes test for X & Y entered 24.5 and it moved 1". When I run the file the router does not hardly move and I'm running in inches. Rechecked my settings and everything set to the settings for my router. Don't know what to do now. This unit was working great at one time before the cat walked across the key board. Took the computer to repair shop and they said everything was fine.
Hi Farv,
Download and run one of the demo Gcode files from the .zip file here;
http://www.machsupport.com/forum/index.php/topic,18345.0.html
Some of these files had been prepared in Inch units and some in Millimeter units. If you use Notepad to view any of the files you should see that they contain the G20 or G21 command (as appropriate) in order to scale the toolpath and the work accordingly.
When you run the axis calibration facility - if you enter 24.5 then the axis should move 24.5 and the appropriate DRO should show 24.5000
Hope this helps,
