Mach Discussion => General Mach Discussion => Topic started by: BR549 on September 10, 2013, 07:17:19 PM
Title: SUB programs
Post by: BR549 on September 10, 2013, 07:17:19 PM
OK the subs for circular pockets and Square Pockets are done. Both are programmable as to size and depth AND conv or climb milling. The square is also rotatable.
Working on the tapping sub now.
Does anyone have a procees they we need to make into a SUB. These can be called from inside a gcode program OR called from the MDI by the use of a SubLoader Mcode
Title: Re: SUB programs
Post by: BR549 on September 13, 2013, 10:20:57 PM
OK I have the Bolt Circle SUB completed. It has 3 functions , Spot Drill, Drill, Tap. You can turn each ON or OFF.
The Bolt Circle parameters are completely programable from Gcode. You define what you need and IT does it.
(;-)TP
Post by: BR549 on September 13, 2013, 10:45:13 PM
I also have the"Ball in Cube" program just about done. This one was FUN to do.
