Mach Discussion => Mach Screens => Screen designer tips and tutorials => Topic started by: Renatox_ on September 03, 2013, 12:31:48 PM
Title: DROs, first screen
Post by: Renatox_ on September 03, 2013, 12:31:48 PM
I'm using the Mach3Screen, with three DROs for XYZ axes. I place, the dimensioned and lined up, I double click and put X position, Y position and Z position respectively and saved the file as mypantalla.set in C:\mach3.
I carry my screen with View-loadscreen and pressed the arrow keys but the indicators remain static.
I also tried to change the resolution of the screen opening Mach3ScreenTweak_Open.set_ControlEdit and the resolution is 640x480, try changing it to 1024x768 and rescale_close but not accepted.
I'm doing wrong?
thanks
Renato
Title: Re: DROs, first screen
Post by: Chaoticone on September 03, 2013, 01:00:28 PM
For jog to work from any screen the screen must have a jog enable led on it.
Post by: ger21 on September 03, 2013, 01:48:00 PM
You should also have a reset button and LED, to make sure the system is not in estop.
Post by: Renatox_ on September 03, 2013, 06:20:44 PM
thanks, now i can move the DROs, both as JogON/OFF and Estop enable these.
To create the RESET, first put a green LED and active (green) and (Flash this LED when active), after create a Bitmap button then double click active (RESET) and put the link of the photo. However, the LED covers the entire RESET button with a dark green color.
As I can do to make the RESET is always visible? and also with the click sound?
thanks
Renato
Post by: ger21 on September 03, 2013, 07:28:53 PM
The LED needs to use the image you want for the button, and the button should use an empty transparent .png file. You can use a 10x10 pixel .png, and size it the same size as the LED. Place the LED first, followed by the transparent button.
I don't believe there's any way to ad sound to a button click.
Post by: Renatox_ on September 04, 2013, 01:11:03 PM
I place first the LED, in property (green) (Flash this Led When active) and (Estop), then put bitmat buttom properties (RESET) and placed a photo .png file, however the LED continues hidden the figure.
I open the 1024.set, and i see the button CycleStart with extension. jpg, and LED green, i try make cyclestart button in the same way, but the LED continue hiding .jpg image.
I charge 1024.set and see the LED only latches on the sides of the rectangle, not the entire area, i still can not do this. what lack?
thanks,
Renato
Post by: ger21 on September 04, 2013, 01:46:33 PM
You need to do it exactly how I said. Whatever you want the button/led combintation to look like, needs to be in an LED image. You then need to place an Image button, and the image must be a blank, transparent .png, placed over the top of the LED. THis is the only way to get a button over an LED and have it work correctly. If you can upload your button and led images, I can probably make a sample to show you how to do it.
Post by: Renatox_ on September 05, 2013, 01:33:25 PM
thanks ger21, i appreciate it. i send two CycleStart and Reset buttons with their respective images.
Renato
