Mach Discussion => Brains Development => Topic started by: mcmotors on September 01, 2013, 10:15:51 PM
Title: axis homing with encoder
Post by: mcmotors on September 01, 2013, 10:15:51 PM
Hello, I'm new to the board, but not Mach3.  I owned a couple of Mach3 powered mills that I sold about 3 years ago, and am building another now for personal use.
I know someone had a board that would use the Z axis encoder pulse to home the axis, I've looked, and as far as I know, they don't sell it anymore.  I had a couple of Mach3 powered CNC Bridgeport mills, and other than the normal floppy BP frames, I could hold .0005 which was required some times.  My only complaint was the limit switches that I used for homing the axis, they would only repeat +/-.002" at best.
Mach3 seems to have made leaps and bounds since then, seems like the imagination limits possibilities at this point.  Being familiar with PLC's, I don't see how BRAINS can't be used to make an encoder driven "axis home".
I was wondering if anyone has a direction to point me in before I try trial and error.
MC
Title: Re: axis homing with encoder
Post by: BR549 on September 02, 2013, 10:38:24 PM
Brains isn't a PLC it has a lot of limitations and quirks.
BUT IT can be done (;-)  You just have to figure out HOW to drive the axis to the index signal.
Post by: zafarsalam on September 04, 2013, 03:57:20 AM
I use vbs macros to home the machines to index pulse on the servo encoders.
I have connected the index pulse with the probe input in Mach3. So if we do a G31 command then it will stop on the index pulse. What I do is home the machine axes using home switches first  (VBS command DOBUTTON(24) etc.). Then do the G31 for each axis.
Hope I made it clear. If you need further help I can send the vb script I use in the home macro.
Zafar
Post by: Ya-Nvr-No on September 04, 2013, 04:59:47 AM
Zafar that is interesting I would like to see that script. Cool idea. I was thinking of replacing a couple of large slaved steppers with AC servos and that would work well for my needs.
Post by: zafarsalam on September 04, 2013, 06:35:15 AM
Here's a part of the macro for z-axis. You can repeat it for the other axes.
DoButton( 14 )
DoButton( 24 )
DoButton( 24 )
While ismoving()
sleep(50)
Wend
code "g91 g31 z-2.6 f50"
While ismoving()
sleep(50)
Wend
setmachzero(2)
Post by: BR549 on September 04, 2013, 03:57:43 PM
IF you plan on doing any probing or TLO that will not work out well as each time you rotate an axis motor you will trip the Probe input.
Just a thought, (;-) TP
Post by: zafarsalam on September 04, 2013, 08:21:18 PM
If I am doing probing on the same machine then I connect the probe hardware through a relay which is enabled by an extra output pin. It cuts off the encoder index from the probe input pin and connects the probe to it. :).
Zafar
Post by: khalid on September 06, 2013, 01:39:15 PM
chhaaaa gya ustad...well done... someday i wish learn all that stuff from u zafar..
