Mach Discussion => General Mach Discussion => Topic started by: Garfield on September 01, 2013, 10:51:27 AM
Hello, what kind of tool do i need to open an .mcc and edit it?
Garfield
All depends what the .mcc is from, if its Lua then I think you will need its editor.
An MCC file is a compiled Macro Script. You can not open and edit it. You would need the source code to do any modifications to the code.
i thought i could change the order of movement of the axis, because there is a bug in it.
Now i will ask the author of the Screen.
