Mach Discussion => FAQs => Topic started by: hmoore01 on August 30, 2013, 09:35:05 AM
Using mach3
When I tell my mill to go to home
the x and y will move first then z last
I want the quill to go up first so it will not crash or break a bit
how do I tell z to home first then x and y
I am new at this
thanks
harry
GoTo Zero is different than homing. The default Home routines home z first.
If you want GoTo Zero to go lift Z first, then enable Safe Z in Config > Safe Z.
thank you for the help
that is just what I wanted it to do
again thank you
harry
