Mach Discussion => General Mach Discussion => Topic started by: xpdingo on August 22, 2013, 10:17:12 AM
Hi
I am new to CNC and Mach3 and this forum has been a great help.
When I am cutting an image the Mach3 screen shows it cutting in a clockwise direction while the machine is cutting in a counter clockwise direction.
Do I have something set wrong and if so how do I correct it.
Thanks for any help,
Pete
You have one or both of your axes (X and Y ) backwards by the sounds of it, you can reverse by changing the active state of the Dir pin from Config menu, Ports and Pins then Motor OutPuts.
