Mach Discussion => VB and the development of wizards => Topic started by: LowryIndustries on August 22, 2013, 04:57:19 AM
I am searching for a script for zeroing Current Position, Machine Coord, and Work Offset.
A am currently using Ver: R3.042.038 which is working fine except when I RefAllHome my x axis moves .0005" (1 step). Apparently this problem may be related to using HillbillyBOB's board and MaxCL. I have been helped by Hood with this, and he is very generous. Unfortunately we seem to be going in circles.
http://www.machsupport.com/forum/index.php/topic,25290.0.html
If there was a simple script which would force the zeroing of Current Position, Machine Coord, and Work Offset, then I simply could append this script to Hiddenscript.m1s and things would be perfect.
Here is the script I have been working on. It doesn't seem to work and I cannot figure out why. It is a replacement for Hiddenscript.m1s with the last part forcing Current Position, Machine Coord, and Work Offset to zero.
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
DoOEMButton(133)
DoOEMButton(134)
DoOEMButton(135)
Xaxis = 0
Yaxis = 1
Zaxis = 2
SetMachZero(xaxis)
SetMachZero(Yaxis)
SetMachZero(zaxis)
Const XaxisMultiFunctionOEMDRONum = 800
Const YaxisMultiFunctionOEMDRONum = 801
Const ZaxisMultiFunctionOEMDRONum = 802
SetOEMDRO(XaxisMultiFunctionDRONum, 0.0000)
SetOEMDRO(YaxisMultiFunctionDRONum, 0.0000)
SetOEMDRO(ZaxisMultiFunctionDRONum, 0.0000)
Suggestions?
Move to new location
'Macro for zero,zero,zero
SetMachZero(0) 'Set Machine Cords to ZERO
SetMachZero(1)
SetMachZero(2)
SetMachZero(3)
DoButton(7) ' Set all Work cords to Zero including fixture offset that you are currently using.
END
Note this does NOT reset any G52/G92 or tool offsets that may be active.
Just a thought, (;-) TP
I'll give it a try!
Thanks!
