Mach Discussion => General Mach Discussion => Topic started by: big_igg on July 29, 2013, 03:06:50 PM
Hey Everyone,
I had a PC running my Tormach 1100 and it quit on me so my friend hooked me up with another PC (same model) So i thought i did everything the same when i went to hook up this PC and the red light does not come on the panel. Not sure if what i did wrong. I have the port numbers the same in mach 3 and when i disable the port and re-able it (in the device manager) i can here the motors like kick in a little, but no red light or movement. I how someone can help me here and maybe I'm missing something simple. I hope!
Okay i think i know that problem, the new pc is set up for 64-bit. Is there a way to get around this?
Only way you can use a 64bit OS with Mach is to use an external controller as the parallel port driver will not work with a 64bit OS.
