General CNC Chat => Show"N"Tell ( What you have made with your CNC machine.) => Topic started by: GRAYHIL on July 24, 2013, 06:41:34 AM
Hi All
Thought I would try this!
http://s285.photobucket.com/user/GRAYHIL/media/flutegrinding.mp4.html?sort=3&o=0
Graham
Getting the flute angle is awkward.
That's fantastic Graham! I dream about a machine like that. ;D
Can you post some details about the machine itself or have you posted something somewhere & I've missed it?
Hi Dickybird
Its a 1950 ish colchester master lathe used as a 4 axis mill . X is the cross slide, Y is the vertical slide and Z is the top slide.
The 4th axis A is a rotary table which can be unplugged and a vice fitted instead.
The vertical slide and rotary table can be taken off and sustituted for the original toolpost and then I can use it as a Mach 3 lathe.
Graham
Not when you have a Darex end mill sharpener......guess I'm spoiled. ;)
