Mach Discussion => General Mach Discussion => Topic started by: mfrisina on February 14, 2006, 03:22:50 PM
Title: Coolant Issue
Post by: mfrisina on February 14, 2006, 03:22:50 PM
I have coolant working well in mach2 but cannot seems to get Mach3 to activate my coolant.  I have configured Ports and Pins, Output Signals so that Output #1 is active with port 1 pin 14. On the Spindle tab, I have Flood using output #1.  When I use the diagnostic screen, when I press the flood button I get a output #1 led.  Still nothing at pin 14 at the controller.  Like I said earlier, Mach2 activates coolant on pin 14 without a problem.  Any Ideas????
Mike
Title: Re: Coolant Issue
Post by: Brian Barker on February 14, 2006, 06:15:13 PM
Look to see that you don't have that pin set to anything other than that function.
If you would like me to I can check the XML for you :)
Post by: mfrisina on February 15, 2006, 02:00:45 PM
Here is my xlm file.  Good luck.
Mike
Post by: mfrisina on February 16, 2006, 07:33:31 AM
Well, I would love to say that you won the prize, but...
I noticed that to and after double checking the config screen, I changed the xml to enable output #1 and asign it to pin 14.  Guess what happened.  The enable #1 led lit on the diagnostic screen!?!?!?! And would you believe there is no enable tags in the xml?
Remember that I said that with the xml the way it is, the Flood Toggle on the diagnostic screen actually toggles the Output 1 LED.
The problem does not seem to be that I cannot toggle the correct LED, just that the signal is not passed to the parallel port.
Mike
Post by: Brian Barker on February 16, 2006, 02:43:52 PM
Set the M8 and M7 to output #1
That shoudl do it :)
