Mach Discussion => Mach3 under Vista => Topic started by: tgdavies on July 17, 2013, 09:19:45 AM
Title: Motor Tuning Dialog Not Appearing
Post by: tgdavies on July 17, 2013, 09:19:45 AM
I'm running an Ethernet SmoothStepper connected to a G540 and then to a Chinese 6040.
I have done the following:
1. Installed Mach3 on a Windows 7 machine and configured my settings -- all good
2. Copied the C:\Mach3 directory to a machine running Vista.
3. Start Mach3 -- jogging works, but when I try to open the motor tuning dialog, nothing appears.
What can cause the motor tuning dialog to fail to open? Are there any logs I can look at?
  Tom
Title: Re: Motor Tuning Dialog Not Appearing
Post by: Tweakie.CNC on July 17, 2013, 10:40:31 AM
Hi Tom,
Welcome to the forum.
This is not the best way to carry out an installation.
Re-install Mach3, from the installation program, onto the machine running Vista.
Post by: tgdavies on July 19, 2013, 09:03:25 AM
Thanks Tweakie -- a proper install was all that was needed.
Post by: Tweakie.CNC on July 19, 2013, 10:20:03 AM
Pleased you got it sorted Tom.
Don't forget to post some pictures of the things you make with your machine in the show'n'tell section http://www.machsupport.com/forum/index.php/board,43.0.html  ;)
