Mach Discussion => General Mach Discussion => Topic started by: trob on July 16, 2013, 02:16:27 PM
Title: Mach 3 problem help needed
Post by: trob on July 16, 2013, 02:16:27 PM
Hi all I'm new here and could do with a little help
I recently purchased a small milling machine equipped with mach 3
I've been using the machine manually with no problems, however today I imported a dxf file from autocad, loaded the g code and when I run the program I have found
that the actual movement of the machine is greater than the movement shown on the DRO.
Mach 3 is not something i'm used to, could this be a simple problem or something more serious, any help would be greatly appreciated.
Title: Re: Mach 3 problem help needed
Post by: Hood on July 16, 2013, 02:38:18 PM
Sounds like the steps per unit are set incorrectly, either that or you have scaling set.
Post by: trob on July 17, 2013, 02:02:24 PM
Thanks for this I have changed the steps per unit and it seems to be ok now
