Mach Discussion => General Mach Discussion => Topic started by: mvoros on July 16, 2013, 02:13:54 PM
Title: Diagnostic Page
Post by: mvoros on July 16, 2013, 02:13:54 PM
Can anybody tell me why output 6 is flashing on the diagnostic page?
Mike
Title: Re: Diagnostic Page
Post by: Hood on July 16, 2013, 02:37:14 PM
You must have something turning it on, maybe a macro or macropump or a Brain or maybe even a plugin.
Post by: mvoros on July 16, 2013, 03:49:02 PM
Thank you Hood. I've been struggling with CNC4PC MPG2 for weeks now. Today I decided to remove it from my system, because we (Arturo and me) couldn’t get the step switch to work on it. Guess what, I deleted the mpg's brain, and output #6 stopped flashing. so much for that problem. There is one other thing you could help me with please. I retrofitted the router with Ethernet Smooth stepper. It works really good, I run hours of hours of long programs from the past without a hitch. The problem I have is when I exit Mach, the spindle starts up. I can work around it, by shutting the control down first, than Mach. I'm using CNC4PC's C41 spindle control board to control the VFD. I can program different speeds, the M5 command works by stopping the spindle. Having used Mach3 for the past 6 years, I never encountered such problem before.
Mike
Post by: Hood on July 17, 2013, 12:46:28 AM
Thats not good, does your spindle controller not use a relay to tell the VFD to go CW or CCW?
Post by: mvoros on July 17, 2013, 06:31:58 AM
Yes it does. The VFD I have is a very simple one, it has only a FWD, no Rev. I think the relay works ok, because the led goes off when I stop the spindle. I took this issue up with Arturo and Greg and they're talking about a pulldown resistor, but do not say how to or where to put it. Attached is a jpg of how the VFD is wired now.
Mike
Post by: Hood on July 17, 2013, 06:42:39 AM
Ok it sounds like they think it is floating when off, best idea is to email Greg and ask his advice on size and location of resistor. Greg is a great guy and will definitely give you sound advice with anything regarding his SS, may just take a day or two as I think his email load is pretty high.
