G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: maitresyoda on February 20, 2007, 09:55:52 AM
Title: Import DXF into MACH3
Post by: maitresyoda on February 20, 2007, 09:55:52 AM
Hello, i would like to import a DXF file into MACH3. The file (see attach) is made with AUTOCAD2007 and TURBOCAD12. When Mach3 importe the file and i generate the GCODE, i can't see the text, only box or circle... I don't understand, can you help me ?? thanks
Title: Re: Import DXF into MACH3
Post by: ger21 on February 20, 2007, 10:31:39 AM
You need to explode the texzt using the Express Tools in 2007. And make sure you save the .dxf as version 12
Post by: maitresyoda on February 20, 2007, 10:53:31 AM
---You need to explode the texzt using the Express Tools in 2007----
Where is this option ? in autocad ?
Post by: maitresyoda on February 20, 2007, 11:25:30 AM
 its ok i install express tools in autocad and mach3 import correctly dxf file. thanks GER21
Post by: frankg521 on July 29, 2007, 09:11:39 PM
were do i find these express tools
