Mach Discussion => General Mach Discussion => Topic started by: Buchanan on July 09, 2013, 10:33:24 PM
Could any body help me .
How do I set up Mach 3 spindle settings for a Gecko 540 and a VFD. Particularly PWM Base Frequency and Mnimum PWM, if this is the correct motor controle to use?
Thank you.
The help here is amazing.
Buchanan
Just downloaded the sample xml from Geckos site and this is what it shows for PWM setup.
Hello Hood.
Thank you. I appreciat that.
I find it a little bewildering to know where to start to look.
Regards
Buchanan
So is it working ok now? You may also have to set up spindle pulleys to suit your setup.
Hello Hood
Yes It is working now but only on and off. I cannot set the speed yet.
I had an incomplete manual for the VFD and needed to change the default settings to external control. i think there is another setting for speed somewhere but i must still find it.
Yesterday my steppers all stopped working and now have the jitters,they twich backwards and fowards one step but wont turn, so i am back in the woods, lost.
Thanks again.
Buchanan
Steppers twitching sounds like you have the step and direction pins round the wrong way.
Hello Hood.
I have checked my ports and pins im Mach 3 and the are pin 2 x step pin 3 x direction pin 4 y step and so on and all seem correct so I went back to first principals and checked my wiring from my g 540 plugs to the motors. We had added an extra set of plugs to go through the machine cabinet wall on the machine and my father had muddled up the wiring sequence so all is well again. For once it was no me that had made the mistake. Thank you for your advice. We are ready to connect every thing onto the mill next so hope to cut metal this weekend if I do not make any more stupid blunders.
Thank you for your patience with a CNC Newbie.
Regards
Buchanan
We have all been there at one time or another :)
I discovered where the wiring error came in. On further investigation by my Father who does not like to make mistakes , we discovered thet out of the five male and female connectors we bought, the males terminals were all numbered the same but two of the five female connectors had terminals numbered differently the the other three. How does this happen.
Buchanan
It happens by humans being human and making mistakes.
Why do you think your father doesn't like making mistakes? ;)
Glad you caught it! :)
Also because where the connectors are made nowadays tends to have a lax quality control, then again the people who get them made tend to want the very cheapest so that they can sell at the most profit and thus it is understandable why QC is low.
I recently got a ribbon cable that had the DB25 on one end assembled correctly but on the other end the shell had been assembled wrong, took me a while to see why it was that I could not seem to get it plugged in. Then I noticed the side with the 13 pins was the short side on the shell and vice versa :D
Hello Everybody
I now have a fully opperational machine. Last night i machined two bearing supports for a frend who is building an anomometer. Imilled two round pockets and both times the bearing fitted in with a few light taps.
Am I ever pleased. The diameter was with in 1/100 mm of the correct size and no flats any where to be seen on the curves.
Thank you every body for your advise and help.
Now I have to fit all the guards.
I will post a few photos when it is all complete.
Buchanan ; ;D ;D
