G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: itolond on July 07, 2013, 09:57:27 AM
Title: Post processor G-code sherline 2010
Post by: itolond on July 07, 2013, 09:57:27 AM
Dear forum,
I have recently purchased a 4 axix Sherline 2010 CNC mill. I am currently using Camwotks and need to develop a post machine for camworks to generate G-code. I have been advised Fanuc OM should work ok however i just want to check on the forum as well as understand a little more myself (if only for self help)
I want to make a psot for sherline using the UPG (universal post generator) from camworks but as g code newbie its a bit of a sharp learning curve. See attached files for reference....
any help or guidance would be appreciated...
Title: Re: Post processor G-code sherline 2010
Post by: Graham Waterworth on July 08, 2013, 02:28:21 AM
Chances are that the Fanuc 0M will work unmodified.
Post by: itolond on July 08, 2013, 05:30:11 AM
thanks for the info, even with 4 axis mill
and the 4000 series lathe?
Post by: BR549 on July 08, 2013, 10:55:16 AM
Idepends on what control system yo have on the sherline. Mach3 or LinuxCNC ?
IF the Fanuc OM does not do it try the Fanuc 6 post
Just a thought, (;-) TP
