General CNC Chat => Show"N"Tell ( Your Machines) => Topic started by: Manley86 on June 13, 2013, 06:41:56 AM
Hey all,
Im well on the way to building my SX3 CNC mach based machine. As this is my only milling machine I wanted to be able to use it as a manual machine too, so after looking on ebay I got three chinese mpg wheels and have made some mounting brackets.
(https://lh5.googleusercontent.com/-IZMZpx2eGaw/Ubmu27eklVI/AAAAAAAAD4g/qWj28eSnWIA/s720/20130608_203146.jpg)
I am also making my control unit in a computer box to keep everything tidy. I plan to fit a 4th axis driver soon too.
(https://lh4.googleusercontent.com/-7pyNZcGGF80/Ubmu4k5Y3JI/AAAAAAAAD4o/8Mpa90-2Uf0/s720/20130611_141553.jpg)
(https://lh3.googleusercontent.com/-9z72nYy5fKo/Ubmu5Tu87JI/AAAAAAAAD4w/rothpsmcwuI/s720/20130612_185122.jpg)
But, this requires two inputs per axis plus some other switches to control x10 x100 etc so my question (whilst showing progress) is: are there any opto-isolated breakout boards which favour inputs over outputs i.e. I want as many inputs as possible, that work with a smooth stepper and mach3 and are cheap......
When I get some more time I will post the progress leading upto this point.
Rob.
I like pmdx 122's. Have a look at their docs on PMDXs site. You can set pins 2-9 as inputs. There small and with the right stand offs you could stack them up. I ran my MPG straight to the SS though, port 3. This gives me no optical isolation on those inputs though. I can't remember all the details of why but the inputs I used for the MPG had to be normal inputs, not outputs selected as inputs (2-9).
The PMDX 126 is a great unit too. It allows the SS to plug in directly. It has expanded mode capabilities that allow more inputs on a single port if desired. It has plenty more abilities I don't even begin to understand ;-)
