Mach Discussion => General Mach Discussion => Topic started by: laco030390 on June 06, 2013, 04:24:57 AM
Hy alls,
In this period im preparing for my graduate exam. My proiect is a CNC turn machine and i want to use mach 3. I istallated but apeared a problem. When i tried manual mode just X axie is working, others doesnt work. The software shows me that its send semnals but the machine do noting. What would be the problem?????? (I tested my driver in Kcam and its working well.)
It could be a configuration issue in which case the Mach3 manual will be of help to you. http://www.machsupport.com/documentation.php
It could be an electrical issue (incorrect wiring) or fault in your axes driver (damaged component) re-check everything thoroughly.
If you are using the computer's Parallel Port then it may be worth checking (pin for pin) your LPT cable as some cables have caused others problems in the past.
Finaly i found the problem. It was the pin numbers. for each motor i associated the common pin numbers but for me needed different, for ex. axie X 2 and 3 for me needed 3 and 2 that was.
Anyway, Thank you for the fast reaction,
All the best!
