Mach Discussion => Non English Forums => Spanish => Topic started by: Ing_Irvingcnc on May 25, 2013, 12:38:43 PM
(http://i00.i.aliimg.com/wsphoto/v0/505511950/5-axis-CNC-Breakout-board-interface-board-Card-MACH-EMC2-KCAM4-for-Stepper-Motor-Drive.jpg)
¿Que es (Fabricante / modelo)
desconozco los datos de esa placa en particular, pero se ve muy sencilla, fijate que debe tener los N° de P1, P2, P3, etc etc,
esos son los pines que deberas setear en el MACH, normalmente del P2 al P9 conectaras tus drivers de motores, en P10, P11, P12, P13, los microswitch o boton de Emergencia o Stop, habria que ver el rel{e a que Pin está asignado, pero podes probar seteando el P14...
Suerte y despues nos cuentas..
(http://img.alibaba.com/img/pb/444/827/515/515827444_460.jpg)
CNC Breakout Board adapter for PC Stepper Motor Driver
CNC interface board, you can make your computer into a powerful CNC controller!
5 axis Breakout board
Compatible: KCAM4 MACH EMC2
Built in DB25 male connector
It is with 4-wire limit switch to insure our safty movement
It is with relay port to contro the cnc spindle
Working voltage is 5VDC and support with MACH3,EMC2,KCAM4 software
25-pin parallel port control is defined as follows:
DB25 control pin (PIN) The pin of the drive board Comment
1 STEPB B(Fifth axis)pulse signal
2 STEPX X(First axis) pulse signal
3 DIRX X(First axis) direction of the signal
4 STEPY Y(Secondaxis)pulse signal
5 DIRY Y(Second axis)direction of the signal
6 STEPZ Z(Third axis) pulse signal
7 DIRZ Z(Third axis) direction of the signal
8 STEPA A(Fourth axis) pulse signal
9 DIRA A(Fourth axis) direction of the signal
10 LIMIT-1 Limit input interface 1
11 LIMIT-2 Limit input interface 2
12 LIMIT-3 Limit input interface 3
13 LIMIT-4 Limit input interface 4
14 DIRB B(Fifth axis) direction of the signal
15 Vacant
16 RLY Relay control
17 EN All axis enable
18-25 GND GND
