Mach Discussion => General Mach Discussion => Topic started by: scrambled on May 19, 2013, 03:27:02 PM
My flame cutter has been working great for the last year. I have not done anything to it besides use it. It is not connected to the Internet, and I have not upgraded either Mach or sheetcam in a year or so.
Yesterday I powered everything up, and tried to jog the cutter. It will not move in high speed.
I reset the DROs and moved the head. According a tape measure it is moving the correct distance.
Where should I start looking?
Steve
Sent from my iPhone using Tapatalk
Not really sure what you are meaning, if it jogs but at a slow rate try holding the shift key down then press the jog arrow obn your keyboard. If that fixes it then you have a slow jog% set on the Tab page.
Hood. It will only move at one speed- very slow. The shift key does not make it go into a higher speed.
It did jog in two speeds. Very slow, and about a 20 % speed
Steve
Has the machine been referenced?
Attach your xml and I will look.
It's a long shot but assuming you are using 'normally closed contact' limit switches then check that there is not a wire off (disconnected) or that one of the switches is not stuck open circuit.
Thanks everyone. I hate to admit it, but I was a victim of a set of bad batteries in my wireless keyboard. :(
The keyboard was working, just not all the way.
I changed the batteries, and I cut steel all day today.
Thanks for all the advice and help
Steve
