Mach Discussion => General Mach Discussion => Topic started by: audio on February 13, 2007, 10:35:01 AM
Hello,
As an alternative to LAZYCAM which are the software names that can properly convert HPGL files (or DXF but first HPGL) into G-CODE? Thank you. .
I use Sheetcam. it can read both hpgl and dxf. It has good contour and pocketing ability.
Its a low cost ( $160+/-) program and has as good support by its author as Mach has.
www.sheetcam.com
ron ginger
See here http://www.machsupport.com/cam.htm
