G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: audio on February 13, 2007, 07:43:36 AM
Hello,
As an alternative to LAZYCAM which are the software names that can properly convert HPGL files (or DXF but first HPGL) into G-CODE? Thank you. ;)
Not that is free... What is the problem?
Hello Brian,
Hello,
Here is my problem : the size of my drawing is not the size of the result in mach3.
I make some drawings in HPGL. They are well imported in Lazycam.
Suppose I import a circle which dia. is 43mm.
Then, Layer/object properties,
I have the hereunder numbers :
- extents X min : 0.0000 max : 1702.0000
Y min : 0.0000 max : 1702.0000
- selectchain X extents > same as above
- stock size stock depth : 0.0000
stock X length : 3651.0000
stock Y length : 3091.0000
Could you please advise what are the hereabove X and Y numbers for these 3 sections?
Thank you very much in advance.
