Mach Discussion => General Mach Discussion => Topic started by: Jackal on April 26, 2013, 08:11:01 AM
Title: If I upgrade to a newer version of Mach will I have to reset any settings?
Post by: Jackal on April 26, 2013, 08:11:01 AM
I am wanting to upgrade to a newer version of Mach3. Apparently,  my version is the one that has the spindle reverse pulley bug. Was downloaded around July 2010 ( I think?????)
I know I can save my .xml file and reuse it. Are there any other settings that I need to make note of?
I have taken pictures of each screen, in the event that something happens and they have to be re-done completely.
JAckal
Title: Re: If I upgrade to a newer version of Mach will I have to reset any settings?
Post by: Chaoticone on April 26, 2013, 08:40:14 AM
I recommend backing up your entire Mach3 folder to a thumb drive or somewhere safe.  Not just when upgrading but just good practice in general.  You will want to save any custom screen sets, macros, brains, licenses files, and xmls for sure.
Post by: Jackal on April 26, 2013, 01:19:23 PM
Thanks Brett,
I appreciate the info.
Can I just install the newer version over the older one? Or, do I need to uninstall the older version?
Jack
Post by: Chaoticone on April 26, 2013, 02:45:08 PM
Yup, you can install over the older version.  You should make sure your profile is named something other than the default Mach Profiles.  Again, shouldn't be a problem if you have your xml backed up but good practice in any case.
Post by: Jackal on April 27, 2013, 09:16:09 AM
Thanks for the help. I'll post any problems or fixes encountered, to help others.
Jack
