Mach Discussion => General Mach Discussion => Topic started by: m9g on April 06, 2013, 06:41:36 AM
Title: HOW DO I TURN WATCHDOG TRIGGER OFF PLEASE?
Post by: m9g on April 06, 2013, 06:41:36 AM
Hi
Machine keeps stopping with watchdog triggered, I have read loads of posts saying I can disable the monitor in config, general config but I don not have a gen config tab in config, can someone tell me where it is please, i'm running MACH3
Title: Re: HOW DO I TURN WATCHDOG TRIGGER OFF PLEASE?
Post by: jimthefish on April 06, 2013, 06:49:46 AM
General config page on the right, about a third down, untick the box
Post by: jimthefish on April 06, 2013, 06:59:49 AM
Sorry forgot to say look in config tab at the top of the MACH page, then its the forth command down. Be prepared for it to not solve your problem, it didn't solve mine it was a problem with the electronics. If it doesn't work put them back on.
Post by: m9g on April 06, 2013, 07:09:20 AM
My fourth one down is called SLAVE AXIS
(http://i132.photobucket.com/albums/q36/mattyninegrand/screenshot_zps67b52eec.jpg)
Post by: Overloaded on April 06, 2013, 07:31:18 AM
That's a pretty old version.
The Dog selection is not available on the oldest ones.
Look under STATE if you have that there.
What version is that anyway ?
Under Help/About.
Russ
Post by: m9g on April 06, 2013, 07:34:04 AM
Version R1.84.002
Post by: m9g on April 06, 2013, 07:36:04 AM
yay!!!! there was an option in state called USE WATCHDOGS so I unticked it :-)
I have also uninstalled everything off the machine that will be running it
Can I upgrade to a newer version?
Post by: Overloaded on April 06, 2013, 07:39:20 AM
.... or under LOGIC.
Post by: Overloaded on April 06, 2013, 07:46:37 AM
R3-043-057 comes highly recommended.
The newest releases seem to have issues.
ftp://machsupport.com/Mach/
Save all of your custom stuff .. screens, macros, brains and your .xml
Post by: m9g on April 06, 2013, 07:55:09 AM
Ok thanks but I click on the link and it says page cannot be displayed
Post by: Overloaded on April 06, 2013, 08:00:12 AM
remove the http:// then try it
Post by: Overloaded on April 06, 2013, 08:02:09 AM
This is a test .....
Post by: Overloaded on April 06, 2013, 08:03:50 AM
yup, posting automatically adds the http:// to the link.
Russ
Post by: m9g on April 06, 2013, 08:37:24 AM
strange, still wouldn't take me there so took the mach/ off the end and it took me to the directory so just then clicked on the mach folder and voila we got there
Post by: m9g on April 06, 2013, 08:49:33 AM
oh
I uninstalled the one I had and installed the suggested one and it says demo, how do I fully register it?
Post by: Overloaded on April 06, 2013, 09:02:55 AM
You probably should have installed the newer one right over the older one.
Did you save your license file somewhere ? It must be in the M3 folder.
Post by: Overloaded on April 06, 2013, 09:15:53 AM
I should say ... Did you have a license to start with ?
Post by: m9g on April 06, 2013, 11:10:41 AM
sorted thanks :)
