Third party software and hardware support forums. => CS-Lab => Topic started by: Joyeuxmael on March 31, 2013, 03:53:48 PM
Title: RYE router Retrofit
Post by: Joyeuxmael on March 31, 2013, 03:53:48 PM
 I am going to use the CSMIO/IP A to retrofit my router, and i would like to share this project from the begin to the end with other persons
My object if is to do the more possible by myself, and i hop it will be helpful for other.
If you think i am posting a the wrong place, feel free to let me know.
Please  apologize me for my English mistake  i am a French dyslexic
I am a 32 years hold wood worker living in Belgium and i Try to Sarto a little bu sines with nested based furniture's.
Few years ago i discover on youtube the  cnc machine and from that day, my mind about my job complexly change.
After a long research about how to Build one by myself, i have choose to go for a retrofit.
So, the 01/01/2010  at  00h04 i win my bid on ebay for an 2550x1550mm table size gantry cnc router.
The machine is a 1993  Rye MG2420  gantry router build in England with a Bosch cc100 control er and Bosch servodyn ac servo.
After a big hole in my workshop roof and a giant crane to move the 6000 kg from my neighbours lane, the retrofit job start !
In  first i try to go with Linux EMC2  and Mesa board but it was not possible for me to get some help with Linux and mesa board.
After one year i stop with Emc2 and get  a professional one man company in France specialized with cnc retrofit.
The man develop and build his own softwar and motion controle board working in analogue close loop controle.
The price was affordable for me, about 1250€ for the motion controle system and 40€/h for the job on the machine......
That was the  perfect dream, until work delay .. And.. Delay again, .. Electronic card wont work....  with a very bad after sale service, and a this time the  job is  not done.
So, because i always look the half full glass insted of the half empty, all that past experience learnt me a lot and i feel glad to understand how it work !
But en ought talking, let's go in the fact:
I have, in working order condition :
The complete electrical drawing
Al the documentation for all component
Bosch AC servo drive , SM drive an VM power module.  +/- 10v. Anal.  Encoder
Hsd electro spindle es919 C axis  7 kw iso30
Yaskawa inverter 7,5 kw
Mitsubishi ac servo 200 w for the c axis
Mitsubishi drive MR-J2S-A20.   +/- 10v. Anal. Encoder
Pnoz
380-220v power supply. ( Spindle fan, Mitsubishi drive )
380-110v power supply. ( Contactor, solenoid )
380-24v power supply  ( aux )
380-24v power supply ( motion controller )
Input
Cycle start
Cycle stop
Vacuum start stop
Dust extration start stop
Spindle clockwise
Spindle counter clockwise
Axis fault
C axis fault
Spindle Inverter fault
X home
Y home
Z home
C axis index
X limite
X limite
Y limite
Y limite
Z limite
Z limite
Hsd Push button tool ejection
Hsd sensor tool locked
Hsd sensor tool ejected
Hsd sensor speed 0
Tool holder magazine parking position  sensor
Tool holder magazine out sensor
Dust shoes up sensor
Dust shoes down sensor
Air supply pressure Stop
Stop
Output
power on  ( contactor for spindle inverter and drive )
Stop
Vacuum pump contactor
Dust extration contactor
Spindle  start stop   clockwise
Spindle start stop  counter clockwise
Axis enable
C axis enable
Hsd  tool ejection
Hsd  solenoid valve
Dust shoes vacuum  solenoid valve
Tool holder magazine solenoid valve
Stop loop. ( Pnoz )
X Y Z limite switch
Spindle, and drive contactor
Mushroom stop x 6
Spindle fault
Hsd thermal switch
Motion control
So i believed the CS- lab product will fit perfectly for my need, i am waiting email answer for me them before to order the controller.
Any advise and future help will be welcome.
 And if some of you use a CSMIO/IP  and could share a wiring machine diagram,  it will help me a lot.
 Happy Easter.
Mael.
Sorry again for my spelling mystakes.
Title: Re: RYE router Retrofit
Post by: Hood on April 01, 2013, 10:02:29 AM
I think you will like the CSMIO/IP-A and it sounds like it will be a perfect candidate for your machine.
 I have the IP-S on a wee lathe and the IP-A on a Chiron FZ12S VMC  and I think the A is the better choice if your drives can accept analogue control voltages. Both are excellent controllers but the IP-A just has some nice advantages over the IP-S
Look forward to seeing your progress.
Oh also I think it will likely be a holiday in Poland today so you may not hear back until tomorrow at the earliest, I know they are very busy with things at the moment.
Normally you would do your build thread in the Show n tell  section but I dont suppose anyone will worry too much about you doing it here.
Post by: Joyeuxmael on April 03, 2013, 07:56:36 AM
Hello,
I have received the Cs-lab reply, they can ship the csmio/ip-A within 3 day.
so i will soon order.
i have start the cabinet job retrofit, i am  Lucky to have plenty of space inside ! ( less outside )
what are the advantage of the  csmio/MPG module instead of a USB pendant ?
Hood, i have read you discussion about the MR-J2S-xxA  servo drive, i will use one for my C axis spindle with the anal 10v signal,  you are very helpfull on this forum,
i have plenty questions in my head but i don't want to harass you, so  it s up to you.
at the moment i am thinking about the main control panel
Power supply ON.   ( computer start ; 24v csmio ; 24v drive and safety component )
Power supply OFF
Drive power ON--OFF ( spindle vfd , axis xyz, axis c,  spindle fan )
CSMIO  Input  / Output  same push button
Vacuum ON--OFF
Dust Ext ON--OFF
Cycle start
CSMIO  Input
Cycle stop ( feed hold )
CSMIO  Input
Rewind  ( to replay the same Code )
CSMIO  Input
Over limite travel  ( key switch )
CSMIO  Input
then i will do the E-stop loop
Pnoz 1 =  XYZ axis  limit switch  and 6 X emergency mushroom
CSMIO  Input
cut all the power supply 24V 110V 220V 380V  except the computer mach3 running
Pnoz 2 = air pressure, power coil contactor, axis drive fault, spindle fault, csmio and computer mach3 fault
drive disable, spindle stop, feed hold move .
i am a bit confused for the E-stop strategy, because if i cut  the main power on my VFD  ( yaskawa 616G5 ) the spindle coast to stop.
maybe a timer to cut the VFD power after 5 second
so i will continue to think about....
good afternoon
Mael
Post by: Hood on April 03, 2013, 03:00:18 PM
I am not too familiar with VFD's as I use servos for spindles. Is there an enable signal on it? could maybe take that away.
What is the proz? I did a google and it seems to be a safety relay but there seem to be quite a few so didnt look up the specs of them. Does it have a timer relay section on it?
Post by: Hood on April 03, 2013, 03:55:16 PM
Sorry forgot to answer your question regarding the MPG Module. I much prefer the way the CSMIO module works than the way Mach works. At the moment Mach3 has 3 modes for MPG, Velocity, Multistep and step . On my other machines that dont have a CSMIO controller I use Velocity and multistep modes, they work reasonably well but when compared to the CSMIO they are not as good. The CSMIO uses a similar method to industrial controls, ie x10 x100 x1000 (for metric) and it is very easy to move in exact steps and motion is good. The later plugins have not had quite as good motion as the earlier ones but I have been in contact with Wotjek at  CS-Lab and they are going to be testing it in the next plugin which should be due for release shortly.
Mach4 will be employing this method of MPG control so possibly a USB or even direct to CSMIO controller MPG may work as well but I think the MPG module will still have the advantage.
 Also meant to mention that you are best to have seperate home switches for each axis as that way you can take advantage of the very precise Index homing that the CSMIO/IP-A can do. It will move to the switch then back off slowly then once the switch closes it will then seek out the encoders index pulse and set that as home position.
Post by: Joyeuxmael on April 04, 2013, 03:57:40 AM
I ave found a  safety relay with a delay for the spindle FVD, so in case of emergency a stop signal will be send then x seconder after the power will be cut.
My machine is fitted with tow safety, tow limit, and one home switch by axis, so the SCMIO many input  will be helpful here.
For the Output i already have 3x 8  relays board on din rail to control the contactor and the solenoid vales.
About the MPG pendant i will see in the future. In my case because the machine is 3,5 x 1,5 m on the floor i  need a pendant about 5 m long
About the future Mach4 soft,  the CSMIO/IP-A-S  should be compatible with the right plug in an firmwar ?
Actually  i am working on the paper with  the CSMIO strategy / implementation / machine wiring diagram.
I am very proud of my self each time i solved a problem, and the Hood answer are always waiting like a child for the Santa Claus to come.
So thank you again.
It s a shame but my ipad wont rename the picture so i c ant upload JPG !!!
Mael
Post by: Hood on April 04, 2013, 06:48:57 AM
Ok you wont need the safety switches as all you need are the limits and homes. You can connect each axes home switch in series with each other so you only need 1 input for them but have the home switches separate for each axis.
You could also if you wished use the extra switches for disabling your servo drives if you wanted but likely that wouldnt be necessary.
You can use your own pendant with the enc module, assuming of course that it has standard type of I/O, ie it is wired and not via USB or ethernet.
Post by: Joyeuxmael on April 04, 2013, 08:17:26 AM
The point is my servo can delivery about 9N/m of torque and the Z gantry is about  1000 kg with rapid moove at 15m/mn  so if the machine go crazy the over limit switch connected  to the Safety-relay will save money !!!
Here is a link of a machine like mine.    http://youtu.be/59fyPL8eo6E (ftp://http://youtu.be/59fyPL8eo6E)
For my machine axis  limits switch's i have 3 possibility using the CSMIO input
6 input   (X+)  (X-)  (Y+)  (Y-)  (Z+)  (Z-)
3 input   (X+ X-)  (Y+ Y-)  (Z+ Z-)
1 input  ( X+ X- Y+ Y- Z+ Z-)
Is there an inconvenient with one of those strategy
Mael.
Post by: Joyeuxmael on April 04, 2013, 09:40:17 AM
For people like me having  their  brain smoking by retrofiting an industrial CNC machine
You can watch this video, solving a  problem could be worst than a cnc ..... http://biertijd.com/mediaplayer/?itemid=40360 (ftp://http://biertijd.com/mediaplayer/?itemid=40360)
Post by: Hood on April 04, 2013, 12:21:33 PM
I wasnt meaning to not have limit switches, what I was meaning was additional safety switches which is what I was presuming you were meaning. ie home switch, safety switch then limit switch.
The way I would do it is all 3 axes limits wired in series and all 3 axes home switches as separates. Wouldnt really matter if you put all limits in as individual inputs but there is no real benefit to doing it that way. It would also make wiring in an override switch easier as you would only require a single pole switch to do that.
Post by: Joyeuxmael on April 05, 2013, 07:15:45 AM
Good news, next week money should come in and i will order the controller.
I have done the IN/OUT  load specifications and  i will have enough IO  with the main SCMIO/IP-A  controller.
here the links of my need and how they will be plug to the board.
Post by: Joyeuxmael on April 05, 2013, 09:40:47 AM
So before i start  drawing  the  all wiring system diagram , i would like to have   opinion of  mach3 users  about the  Machine Start up procedure
Switch on procedure
1. Switch mains isolator ON. The transformers 24V  110V  220V  are powered.
2. Push the green button "SYSTEM ON".
   2.1  The Mach3 computer will boot up.
   2.2  The system  contactor get closed.
   2.3  The CSMIO controller and the SAFETY closed-loop is powered in 24V
   2.4  The Bosch servo drive are powered in 24V
   2.5  Emergency stop is activated because of the drive 380v main power is missing  K01
3. The Mach3 control display  shows "DRIVE FAULT" and "E-STOP"
    4    Reset the fault in Mach3 to activated the drive ( drive enable )
    4.1 Push " DRIVE ON "  button for 5 seconds until  K01 stay closed  ( drive enable signal got trough the  K01 380v NO contact  )
    4.2  this action will bypass  E-STOP loop by powering directly the  Safety relay  ( PNOZ-X3 )
    4.3  this will closed K01 and enable drive power stage
    4.4 the drive ready signal ( drive fault ) is now close in the safety loop emergency circuit
5. Machine is ready for automatic  HOME POSITION
DRIVE ON  will be use after an  EXTREM OVER TRAVEL , in this case turn the switch OVERRIDE ON  and Hold down the button until you cleared the switch by jog the axis in the opposite way
If the machine reach an Axis limit switch, turn the switch OVERRIDE ON  ( this will bypass the open limit switch by delivering 24v signal to the controller input )
Post by: Joyeuxmael on April 05, 2013, 10:02:07 AM
Picture of my RYE CNC router
When the truck delivery me the machine the way was FROZEN so i get the help of the neighbour with a crane... pulling the truck !!!
that was the beginning of a long day,
Post by: Hood on April 05, 2013, 03:02:23 PM
Looks like a nice machine, not what people usually think of when you say you have a router, thats a real one :)
I do a similar kind of idea to yours except my main isolator is used to switch on the mains to the 24v power supply and also mains to things like the computer, so I can switch on the computer from my panel.
 My drives contactors are powered via a switch on my panel (On/Off button) this powers the drives and coolant pumps and also shuts a contact so that my E-Stop string is closed. If I dont power the drives via that switch then I can not reset Mach as the E-Stop is open.
Post by: Joyeuxmael on April 05, 2013, 03:31:47 PM
So, i am in the good  "Industrial" way
The point is i don't TRUST in  Windows computer for my safety.  I prefer coil and mechanic.....
A question about MACH ? It is possible to reset an emergency fault in mach3 ( axis not ready ) until i powered them up ? it is because a need a close contact drive enable.
if not, i will put a by pass to shunt Mach3 during the launching phase.
Post by: Joyeuxmael on April 05, 2013, 03:43:01 PM
Pictures
Post by: Hood on April 05, 2013, 04:17:52 PM
Not really sure what you are meaning. What is the emergency fault signal? Is it the E-Stop input or?
Post by: Joyeuxmael on April 05, 2013, 06:08:38 PM
Yes it is the csmio/ip E-stop input
So my POWER ON push button will have 3 effect
Bypass the safety loop
Bypass mach3 drive enable
Powered the PNOZ safety relay solenoid
After 3 second if all the motion equipment  are working correctly the safety loop is self-maintening and you can release the POWER ON
It is a kind of STARTER !   I should call it   " IGNITION "
Post by: Chaoticone on April 05, 2013, 06:15:13 PM
Make that button a momentary key switch and crank that baby up.  ;D
Post by: Hood on April 06, 2013, 03:26:34 AM
Yes that should work fine. :)
Also have the drive fault signals set up as the dedicated fault signals in the plugin and that will halt all motion and E-Stop Mach if a drive faults. You need to home the first time you switch Mach on but after that you will just have to reset Mach and it will know where it is, assuming of course you keep the logic side of your drives powered.
Post by: Joyeuxmael on April 06, 2013, 04:44:59 AM
Good morning Hood.
Your last post give an other way of monitoring E-stop by tow stage
First stage, shut down power if : axis reach  over limiter or emergency stop button is pushed
Second stage, disable the power stage axis and fast stop the spindle if : a fault happen ( drive, thermal switch ... )
The  advantage is to be able restart the job by pressing cycle start when the problem is found
I  worked in the merchant navy, few years ago and they have the same problem.
If an  uncritical engine alarm is displaying the engine continue to run, we have a computer telling us what up. during the night  it give us the phone number of  cabin mechanic man.
But if  oil vapor is detected in the dry crankcase  :'(.  The engine is automatically stop by the computer !!!!! Before it explode  >:D
And if you are by night in the storm with the alternator coupled to this engine, you loose all the electrical power and propulsion !!!!!
But you  are not burning in hell, just adrift.....
So which way is the best about CSMIO. One stage or tow Stage E-stop ?
Post by: Hood on April 06, 2013, 05:00:44 AM
Its not really a two stage as such, just  multiple inputs that will do the same thing.
If you whack the E-Stop button then the CSMIO will see that and E-Stop Mach.
If one of your drives faults then the CSMIO will see that and E-Stop Mach.
In either case as long as the logic side of the drives is still powered  you will still have encoder fed back to Machs DROs so sort the problem and Mach knows exactly where it is.
At the moment the spindle does not have an error input but I am hoping that is fixed in the plugin currently being done.
Regarding the engine management, there was similar in some of the lifeboats here and it was actually a bad thing.  Not a great idea the engine shutting down as you are coming into a harbour in heavy seas, much better to allow the human to decide if its safer to allow it to keep running and risk it blowing up in such situations.
Post by: Joyeuxmael on April 06, 2013, 06:17:24 AM
The worst example at sea  " ship fire figthing plan "
Commercial navy: they check if nobody is present in the engine room be for opening the CO2  system
Royal navy :  they open the CO2  first then,  then count the man ...... Left outside !
So, my decision is take  to let mach3 and csmio ruining  automatically  Emergency stop.
Expect for the Mushroom button and the axis over limiter which will shut down the power and make the position lost.
I believe, in case of mach3 fatal crash, the csmio E-stop output will be automatically  open ?
Post by: Hood on April 06, 2013, 09:43:56 AM
The position will only be lost if you also remove the logic supply from your servo drives, I think most drives (commercial ones anyway) can have the mains taken away but usually the logic side supply can be kept intact.
If Mach crashes it may or may not E-Stop, just depends on how it crashes I suppose. Good thing however is you should still have the CSMIO watching things and it should see a fault and halt things, so kind of double safety check there with Mach and CSMIO both looking for faults.
Post by: Overloaded on April 06, 2013, 10:10:50 AM
That is the way the ones are that I'm using.
The Control Power is tapped into the mains up-stream of the contactor (M).
FYI,
Russ :)
Post by: Joyeuxmael on April 06, 2013, 10:40:13 AM
My Bosch drive have the logic powered in 24v so i haven't try but it should worked has you said.
Any way i do prefer losing the position and a 30€ plywood board than a motion component €€€€
I am not in aerospatial business with a 12 axis CNC machining a bloc of Titan during 15h.
I am actually working on the electric diagram and i found a very friendly  CAO soft ( free )
http://qelectrotech.org/wiki/en/start (http://qelectrotech.org/wiki/en/start)
The component library are complete enough for my project.
Post by: Hood on April 06, 2013, 12:25:42 PM
I think maybe you are misunderstanding or maybe me that is misunderstanding.
What I am saying is Mach can E-Stop, CSMIO can E-Stop, Limits can be hit, Drives can fault etc etc but as long as you do not take away the 24v logic supply then the encoders will always be monitored and thus simply sorting the fault and pressing reset is all that is needed. Homing again can of course be done if you wish but it will not add any accuracy to things as the position is already known.
