Mach Discussion => General Mach Discussion => Topic started by: gtxkid on March 29, 2013, 01:03:33 PM
Title: Who can i call to get help with a setup problem on Mach 3
Post by: gtxkid on March 29, 2013, 01:03:33 PM
  I have a mill setup with Mach and been having a hard time getting it going.
I think we are close but i would like to call someone to go threw a quick trouble shooting.
Title: Re: Who can i call to get help with a setup problem on Mach 3
Post by: Chaoticone on March 29, 2013, 01:09:58 PM
Sent you a PM
Post by: gtxkid on March 29, 2013, 07:37:24 PM
  Thanks Brett ;D ;D ;D
You got us a lot further along. ;)
We found the wiring wrong on the Z axis servo motor. ???
It was a great feeling to see  it move. 8)
  Is there a setting in Mach to tell Mach that it is looking at C32 board.
Problem we are having is setting up the steps per inch but when we
give it a move command it goes a totally different distance.
Post by: Overloaded on March 29, 2013, 07:49:04 PM
There is a complete chapter dedicated to this in the manual.
Mach3 Install & Config. Guide
Up top, under SUPPORT/Documentation
Russ :)
Post by: Chaoticone on March 29, 2013, 09:45:46 PM
Good, you will be slinging chips in no time now.   :)
A couple of these links will help in setting up your steps per and a couple of others that you will want to check right after you get everything moving the proper distance.  Also, the manual Russ is referring too really is a must read for Mach users.  You will be doing yourself a favor to study it front to back.
http://www.machsupport.com/forum/index.php/topic,16315.0.html#new
http://www.machsupport.com/forum/index.php/topic,12512.0.html#new
http://www.machsupport.com/forum/index.php/topic,10308.0.html#new
http://www.machsupport.com/forum/index.php/topic,12513.0.html#new
Post by: gtxkid on March 29, 2013, 11:06:41 PM
  Got it.
This is great.
We are finally getting somewhere.
